RCA 21AXP22 picture tube/rebuilt picture tube
What is the better tube a original RCA 21axp22-a or a rebuilt 21axp22-a picture tube by rca in the 50's? Which one is worth more? I have one of each and both test very good. Would a original 21axp22 make the set worth more, or dont it matter? Thanks
Naturally, the OG tube will please the purists more.
Even if the rebuilt 21axp22-a was done by rca?
Is a virgin still a virgin after being 'broken in'?
I'm not a purist, personally I hate that stuff, but you know how 'they' get. lol |
Thanks for checking things out here. John |
What does it mean? Is a metan cone 21AXP22 more fragile and dangerous than an all-glass tube?
oldtvsandtoy, the non- rebuilt one should go in your set and the extra one could have a happy home in my Wingate Poke poke.......
My TV page and YouTube channel Kyocera R-661, Yamaha RX-V2200 National Panasonic SA-5800 Sansui 1000a, 1000, SAX-200, 5050, 9090DB, 881, SR-636, SC-3000, AT-20 Pioneer SX-939, ER-420, SM-B201 Motorola SK77W-2Z tube console McIntosh MC2205, C26 Last edited by zenithfan1; 06-27-2010 at 11:07 PM. |
If I needed one I wouldn't care which one I got as long as it worked!
If they are both 21AXP22A, I would say it makes very little difference. I would go with the unrebuilt crt myself. It would be a very, very particular person to really make an issue of that.
There were some earlier 21AXP22 (non-A) tubes that would be more desirable, I feel, but they seem to be rare. I'm a little more nervous handling a metal-cone crt myself. From what little details I've seen, it seems that they can be pretty nasty when they implode.
Bryan |
Quick confirmation needed here.
When I fixed the flyback on my CTC-5, 21AXP22A guns started to glow neon blue & red. I had assumed the tube would have been fine but now tested it and filaments light nice deep red (meaning air not a problem ? as I would expect warmer orange color with air present ?) On B&K tester a "short" shows up (in fact a 68 k ohm leakage heater-to-blue cathode) B&K book said in this case use an isolating filament transformer - which I did but same symptoms --- and, by the way, ZIP in the way of Emission. So is it air ? Who rebuilds these now? |
![]() What happens is the gas conducts heat away from the filament, and causes it to run cooler, hence the darker/dimmer red color. Now this may seem bass ackwards, but the heater is more likely to burn out when it is running this way because the resistance of the cool heater is much lower than when it is at normal operating temperature, so that it will blow out like a fuse that has excessive current running through it. sad, jr |
No one, like I said join the litany that is sad AXP owners praying for a rebuilder.
Evolution... |
On my tube there will be nothing on the meter, then as you advance the control it will peg at full. This is the typical 'gas regulator' action which indicates a gassy tube, sorry for your loss. Join the club.
Evolution... |
It sounds like air to me too. Besides the action miniman82 mentioned the air cools the filament so that it will be a deeper red rather than orange or yellow.
Was it the filament or G2 that you turned up ?
Did you get the glowing light show around the guns as well ? Rebuilding may not work if there is glass-to-metal leak ? Might drop in an all glass roundie if mounting is not too much hassle |
