Old 10-23-2010, 10:26 PM
Philco 60 restoration
I figured I start a new thread on this Philco since it's no longer a mystery
I brought it inside and took a closer look at it. The cabinet is nicer than I realized at first.
Of course, it has the dreaded metal caltrop feet. I pulled those and put on some felt pads
Here it is next to my 70 which has been badly refinished (not by me!).
I really hate the way they hard-wire these speakers. The only way to pull the chassis is to cut them or pull the speaker too.
There's been some work done on it. Looks like they just tacked the new caps across the old There are some new resistors too.
I should probably get a new dial scale since this one has warped.
Old 10-23-2010, 10:28 PM
Originally Posted by leadlike View Post
You know, you might be okay with the open coil thing-the escutcheon is of the newer style ('35+) which seems to be after about the period where they altered their manufacturing practices. Just having a nice cabinet like that is great: if I had come across this one, I would be happy that I finally had a cabinet for my Midwest chassis.
Thanks for the info - I'll keep my fingers crossed.
Would the controls on a Midwest line up in this cabinet ?
Old 10-23-2010, 10:53 PM
I was doing a little research and stumbled across Phil's excellent restoration writeup: http://www.antiqueradio.org/philc08.htm
That will be a big help for sure
Old 10-24-2010, 11:08 AM
leadlike's Avatar
leadlike leadlike is offline
I've always redone the wiring on Philco speaker harnesses-they just don't seem to hold up that well. I have a roll of cloth-covered brown wire for just such a purpose. As far as the tacked-on repairs go, that is how they all seem to have been done. I know Philco had radio-counter displays so you could grab the replacement bakelite block you needed, but they apparently never sold many of them.
I restuff bakelite blocks, but I don't use the heat gun/oven methods, I just pull the block, and chisel out the guts with a small screwdriver. It takes about two minutes to get them all cleaned out. One of the blocks in my 60 had two mica caps in it, so I just let it be, since the other micas in the set tested fine.
Old 10-24-2010, 01:29 PM
Reece's Avatar
Reece Reece is offline
I'm always harping on this, but I would put a plywood bottom shelf under that speaker all the way to the back of the cabinet to enclose the bottom of the speaker compartment. The way they made them there's an acoustic short circuit from the front to the back of the cone: result, less bass.
Reece
Old 10-24-2010, 06:50 PM
Philco may have done it (less bass) to avoid too much hum from the power supply.
Old 01-13-2011, 08:09 PM
polyphase polyphase is offline
I have to agree with this. A 250Hz tone has a wavelength of about 4ft, so at least a partial acoustic short circuit would exist here, right in the critical lower midrange. 100Hz material, if deliverable from this set (I suspect it is), would pretty much be cancelled out.
Old 10-24-2010, 04:03 PM
I have some three-conductor cloth covered repro. wiring around here somewhere too. The guts are popping out of a couple of these already so I'll try your technique. Hot stinky tar isn't much fun
There's also a 5-section cap in a metal box. I hope that won't be a pain to restuff.
I hope I won't need to do an alignment.
I'm amazed at how many trimmer caps there are. Something like 7 in total.
Thanks for the suggestion. Once I get it working, I'll do a comparison with and without a bottom shelf.
Old 10-24-2010, 07:28 PM
Reece's Avatar
Seems that (some) early moving-coil speakers, especially those with the spider screwed into the center of the pole piece, had a kind of stiff action and didn't have all that good bass response and so the power supply didn't have to have the best filtering, and since larger filter caps were expensive...could be that the speaker, the speaker mounting, and the supply filters were all serendipitously ideal for the situation.
I think I read somewhere another idea about cleaning out those capacitor blocks: put them in the freezer for a while and the tar is easier to chisel out. Does that ring a bell?
Reece
Old 10-24-2010, 08:28 PM
leadlike's Avatar
The metal box isn't tough to work on. Just undo the nuts, pull back the tabs on one of the sides, and the wax-covered guts just slide right out. You'll spend more time wiring the replacement caps and wiring harness up.
Old 10-25-2010, 07:01 PM
radio63's Avatar
radio63 radio63 is offline
Still Y2K Compliant!
I used to use an old pencil soldering iron, and plunge that into the tar on those black bakelites. Usually working one side of the cap, you could gently pry the whole assembly out. Have to be careful not to apply too much pressure to the side of the bakelite case, or it can break. Don't forget to check for soldered leads on those. It was a little messy but not bad. I think freezing the caps might be another option though I never did that myself. Keep us posted!
I think your dial scale may be fine. Most of them are warped. I would try placing it in a warm location and weighing it down to straighten it out. That might help. I would try doing that before getting a repro scale.
Gilbert
I don't know anything about ignorance and I could care less about apathy.
www.galaxymoonbeamnightsite.com
Old 01-08-2011, 01:12 AM
Originally Posted by JoeNewberry View Post
Thanks for the link on furniture restoration. I'll definitely give those videos a watch before I start.
Personally, I love the smell of Gojo because it always brings back memories of my dad. He was an auto mechanic and used it religiously for cleaning the grease off his hands. I figure if it was good enough for that, it can take off 70 years of accumulated grease and oil on my radio.
He goes fast in those videos but covers an amazing amount of topics. I definitely recommend repeated viewings.
I got some of the lithium grease on my hands and boy does it stick. I was glad to have the Gojo handy.
Gilbert
I've been putting weight on it for about a day and it is showing signs of improvement. We're heading into another cold spell though so I'll need to put it near a space heater to keep it warm.
Old 10-25-2010, 09:04 PM
Thanks for all the great tips! I'll definitely keep you guys posted. I plan on digging into it soon
Old 10-25-2010, 09:17 PM
mbates14 mbates14 is offline
make sure to do videos :-]
Old 10-30-2010, 12:06 AM
For sure. Two up already - check my channel.
I decided to take a little time tonight and try to spruce up the cabinet.
Here's the top as found
I used some Howard's Restore-a-Finish Walnut on it and slowly worked out the paint and stains.
The fluting had some nicks and dings. The Howard's hides it a bit as would some stain.
I used a brush dipped into Howard's to clean out the recessed areas and steel wool to clear off the paint.
I can't do much about this kind of damage
I follow the Howard's Restore-a-Finish with some Feed-n-Wax (orange oil and beeswax) and some Old English Lemon oil. This old wood was really thirsty
Here's how it turned out. Still some more cleaning to do in the nooks and crannies, but otherwise a great improvement.
I do like to preserve and old finish when possible
I certainly has more character than that badly refinished 70.
Can anyone spare a couple black hex knobs ?
