what next
I have a CTC 5 blonde table top (faux fin on some kind of wood product) and a metal cab CTC-7 faux finish blonde table top.
Since I just got done with a 5 I am tempted to take on the 7 just for something different. The 7 is in very ruff shape. lots of rust on the cab some on the chassis. I am thinking get the chassis going and then if all good maybe just get a sanding disk and go to town on the metal, and then repaint some kind of hammertone grey, or try one of those faux wood finish kits I see for metal house doors (sounds tacky I know). comments are welcome as I have not made up my mind. |
Here is the 7, I really like the mask on this one.
Go for the 7! Mine worked beautifully after only a basic recap. Some day I'll go back and do a complete setup (convergence, etc.) but the picture looks so good that I'm not very motivated.
Did that "tabletop" come with spindly wooden screw-on legs like my CTC-11, or was is truly intended only for tabletop use? Phil Nelson Phil's Old Radios http://antiqueradio.org/index.html Last edited by Phil Nelson; 02-20-2013 at 01:31 PM. |
It has the place for the legs but did not have them when I got it. also does not have a back, so I will end up making one (from perf metal).
Hi All;
Maybe you could use naval-jelly like Admiral Bob.. But, of course you'll have to check and see if it only works on Admirals.. THANK YOU Marty |
I vote for the 7, too. I have the same model (the Abington) in faux mahogany. It's also missing the back. When you come to fabricating one for yours, I'd like to compare notes.
Mine also came with no legs and I didn't think that it had the threaded holes to accept them, but if yours does mine probably does too. I'll have to check. Good luck, Clark Last edited by IsthmusTV; 02-21-2013 at 01:58 PM. |
If you fix up the CTC-7's cabinet nicely and try your spare CRT in it, that may encourage you to work on the CTC-7 chassis and end up with a nice, complete working set. I am trying the same process with a beat-up "boat anchor" Hallicrafters shortwave receiver right now. Restore the cabinet and chassis cosmetics first, then I will definitely want to do the circuitry!
I double checked the 7 cabinet there is NO mounts for legs, my bad, it does have some rubber feet around the perimeter.
hmmm a quick look at the top of the chassis shows mostly dipped maroon caps, nice, I think pull the output tubes and do a variac check.
One of the top hats (mounted on top of the chassis) has corroded off its lead. Will have to dig thru my stash for a power diode before doing anything.
there is also some old looking device that it bolted to the side of the chassis (inside) it looks like some kind of mechanical breaker but I cant see a reset will have to look a bit closer to see what it does. it does connect to the power switch. going to take a look at the schematic and see if I can figure it out. some of the pots on the side are nice and crunchy, yuck. |
That's a time delay relay. It puts resistance in series with the AC input for about 20 seconds to control the inrush. Then you hear a "click" and full voltage is applied. I believe it's some kind of bi-metal deal like in a toaster. -Clark |
