Old 01-10-2014, 09:21 PM
Scored a CTC 9 locally!
It appears to be a model 210-CK-85, the "Anniversary" model according to Ed Reitan's Site.
It's complete except for the CRT cup but the cabinet is a bit rough.
At some point in the dim past someone covered it with hideously ugly contact paper, all shabby, no chic. Also the top has some blisters in the veneer, it looks solid other than that though.
It still has the original 1959 21CYP22 installed and it tested quite weak, even 9 volts wouldn't bring it all the way up, however a gentle cleaning and a very light restore on the red gun brought all three guns up to like new with a long life test. I don't know how well it'll hold up but it's encouraging.
Chassis looks clean from what I can see through the back.
Got this for $50 figuring even if it's just a parts set it's worth that.
What it should look like:
What it does look like:
Old 01-10-2014, 09:38 PM
mstaton's Avatar
mstaton mstaton is offline
"Book em Dano!"
That's some hideous wallpaper!
Old 01-10-2014, 10:01 PM
Now that you mention it, it might be wallpaper, I was thinking contact paper but maybe not.
Does anyone know what type of finish this set had, Photo or real veneer?
Old 01-12-2014, 10:43 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
I have the same set. The top panel is veneer... the sides are faux.
Charlie Trahan
Old 01-11-2014, 12:18 AM
sampson159's Avatar
sampson159
ouch!i love the style of this set.peel that and lets see some wood!great,great score and this is not a parts set.its a restoration.it deserves its dignity
Old 01-11-2014, 01:31 AM
Even if you have to hook a brightener to it it should look ok , its not like your going to be running it 5 or 6 hours a day , I have a couple color brighteners that are collecting dust , so for $50 even with the wallpaper it was well worth it
Old 01-11-2014, 07:38 AM
hi_volt's Avatar
hi_volt hi_volt is offline
Vintage TV and Radio Nut
Very nice score. Definitely a "restore" set, and the price was right. Looking forward to seeing what the set looks like under the contact paper.
Old 01-11-2014, 10:21 AM
John Marinello's Avatar
John Marinello John Marinello is online now
<-- "Byron"
You should have asked if they still had the matching drapes...
Old 01-11-2014, 01:24 PM
Whoever did that deserves a good Kicking...
Old 01-11-2014, 02:21 PM
Steve D.'s Avatar
Steve D. Steve D. is offline
The more I look at the photo of the top, It looks like paint rather than wallpaper. In any case stripping the paint/paper could reveal, hopefully, a solid wood underneath that could be refinished. Not sure if this particular model used hardwood or fiberboard cabinets.
-Steve D.
Old 01-11-2014, 03:16 PM
On closer inspection it is paint.
The cabinet feels like fiberboard, probably with a faux finish that wouldn't survive stripping. The only cure would be Veneering it.
Old 01-11-2014, 04:04 PM
Steve D.'s Avatar
Eric,
Normally wouldn't recommend this, but if stripping and light sanding is successful and you have a smooth fiberboard result. How about spraying the cabinet w/primer and a high gloss black paint. Of course first removing all items/trim and carefully masking other areas. Like me, you live in So. Ca. and the weather is warm enough right now. Paint in a well ventilated area. Just a suggestion.
-Steve D.
Old 01-11-2014, 04:14 PM
Originally Posted by Steve D. View Post
Eric,
-Steve D.
Steve, I have thought about that, might look good, or maybe I could apply a "Heywood Wakefield" type of Limed Oak Lacquer.
Sometimes Fiberboard can soak up paint like a sponge leaving a rough looking finish, perhaps Primer or Sealer is the trick to fix that.
Here's a shot of my Wynnwood after painting it, Black Lacquer is the original finish on this set, it really sets off the Brass accents, some of which are not reinstalled in this photo.
Old 01-11-2014, 07:18 PM
Carmine's Avatar
Carmine Carmine is offline
...enjoys spaghetti.
There was a guy here who restored a set using silver paint to make it look like a newer model. You probably won't fool anyone with that football-shaped screen, but it's another idea!
From Captain Video, 1/4/2007
Old 01-19-2014, 01:30 AM
Tubejunke's Avatar
Eric,
-Steve D.
I know that the set has been found to have real wood, but I thought that it would be worth adding something I learned from the TV show American Restoration. I can't remember what they were doing this to, but they showed a way of imitating a wood grain on something without real grain like fiberboard. What he did was laid down first a light brown coat coat of I think stain and then blended in some darker accents on top of that. Finally he took something like a trim brush; a small brush, and ran long strokes in what to the viewer seemed to be random parallel areas. I say that because the man said that there was a bit of an art to it and it takes practice, so it's not quite random, but more strategically planned.
At any rate, the end result was great. It really looked like wood grain. So, maybe this will help someone else who finds a TV that probably survived a hippie owner in the 60s or 70s who tried to make the world a little more beautiful, but failed....
