Slip Plate sprayer and valve cloging
Some time back I bought a can of Slip Plate to recoat some CRTs that were shedding their original dag.
I've only done ~4 CRTs (used roughly half the can) and fairly early I've noticed that the nozzle clogs a lot I've been cleaning it by pulling it off and dipping it in GoofOff. The first ~3-5 times it worked okay and did not re-clog too fast, but it has come to the point of clogging almost instantly after cleaning. I eventually made the nozzle orifice bigger and that has not helped much. It seemed before that it was only the nozzle clogging, but now it seems the can valve is also doing it since sometimes it stops spraying and the valve is clear. Last time after some spraying I finished by pulling the nozzle and sticking a paper clip in to force the valve open to BLAST coat the last patches...At the rate things are going I'm going to run out of propellant long before I run out of the liquid in the can....I'm thinking of punching a hole at that point and decanting that into a jar to brush on to more tubes (it ain't cheap so I want to get all I can out of it). Has anyone else had this happen or did I just get a bad can?
Are you shaking the can well? That stuff tends to clump easily and will clog the spout when you try to spray.
Was shaking it decently. It ran out of propellant last night so I did an autopsy...The valve was making crunching sounds in operation. After making sure there was no pressure in the can I punctured it and decanted the remaining paint into a twist off glass soda bottle (for future use) and cut the can wide open...The 'mixing balls' were a pair of the most chipped up glass marbles I've ever seen....
My theory is that after a few uses (read times shaking it) the marbles made enough glass chips that every time I unclogged the sprayer new ones would be rapidly sucked up and re-clog it...
I bought a lot of CRT's from there and they stood up well. |
