Old 09-16-2017, 05:37 PM
TUD1's Avatar
TUD1 TUD1 is offline
TheUniversalDave1
My new CTC-15
Got this CTC-15 today for only $32. It had the original tube, but it was replaced because I wanted the rare earth phosphor.
"If you wish to make an apple pie from scratch, you must first invent the universe." -Carl Sagan
Old 09-16-2017, 07:30 PM
Findm-Keepm's Avatar
Followin' the Rules...
Sweet! And inexpensive too!
Brian
USN RET 22YRS (Avionics/Cal)
Old 09-16-2017, 07:48 PM
Celt's Avatar
Celt Celt is offline
Peanut Head
Good lookin' set!
Old 09-17-2017, 01:22 AM
TUD1's Avatar
TheUniversalDave1
Finally fired up the CTC-15. Check out that incredible picture!
Old 09-17-2017, 02:08 AM
MadMan's Avatar
MadMan MadMan is offline
The Resident Brony
Noice.
Old 09-17-2017, 10:34 AM
mr_rye89's Avatar
mr_rye89 mr_rye89 is offline
Nice! I've been after something similar for a few months now. I'm still convinced no one in my neck of the woods had color until the solid state era......
also that Futurama subtitle is hilarious
Old 09-17-2017, 12:01 PM
Great find. As you're probably already aware, the two ground stakes on the far right end of the chroma board exist in two states: either cracked or gonna crack soon. They need to be re-flowed as a matter of course on every CTC-12, '15, '16, '17 and '25.
When they fail, the heaters on the 6GU7s go out, causing the plate voltage to rise. Since the plates are DC-coupled to the CRT grids, this makes the CRT beam current go nuts, lugging down the HV supply. Pic blooms, loses focus and fades out.
Old 09-18-2017, 07:31 AM
Tom S's Avatar
Tom S Tom S is offline
Very nice set. If you have your other tube I'm interested. Have a CTC11 I would like to improve. Thanks
Tom Smrz
Old 09-18-2017, 02:02 PM
TUD1's Avatar
TheUniversalDave1
Had to trade the old tube for the new one.
Old 09-18-2017, 07:45 PM
TUD1's Avatar
TheUniversalDave1
Well, I'm fighting my first battle with the CTC-15 already. The CRT keeps randomly loosing filament voltage. I took the back off, inspected the socket and CRT base, and put a drop of Deoxit on the filament pins, and that fixed it. I put the back cover back on, and it's out again.
PROBLEM SOLVED. Had to heat up the CRT pins.
Old 09-19-2017, 08:40 AM
kvflyer kvflyer is offline
Heck, take it back for a warranty claim on the CRT.
Looks nice...
Old 09-19-2017, 12:02 PM
TUD1's Avatar
TheUniversalDave1
This is becoming the most problematic TV I've ever owned. I had to fix the CRT filament again last night, and I decided to just leave it away from the wall with the cover off. It was working perfectly fine when I went to bed, and when I got up today, I had no blue, no red, and a whole lotta green. I tried swtching the 6GU7's around, and after that I got no green, and whole lotta purple. So then I go find another 6GU7, and put it in the G-Y/blanker tube socket, and the green was still dead. I'm at a loss.
Old 09-19-2017, 12:17 PM
Has the solder ground stakes/traces on the chroma board been reflowed?..If not then you will want to do that.
Old 09-19-2017, 04:33 PM
TUD1's Avatar
TheUniversalDave1
New tubes, clean sockets, solid solder joints, FTW.
Old 09-19-2017, 04:51 PM
