Old 12-12-2017, 04:43 PM
benman94's Avatar
benman94 benman94 is offline
Resident Lunatic
Strange experiment in post-war electrostatic set design
I found this paper while looking for references to the 10HP4 and 7EP4 CRTs used in Transvision kit sets. This has to hold some kind of a record for a television set with the fewest number of tubes until the invention of the first practical transistor and the Compactron. Just 13 tubes, and of the 13, two are only rectifiers, plus a 7JP4 CRT. I own radios with a larger number of tubes...
Also, does anyone have any information on the Sylvania type SR-1022 listed as a larger alternative to the 7JP4. A developmental number for the 8BP4 or 10HP4 perhaps?
Anyway, I thought some of you might find this to be an interesting read, I know I did:
https://calhoun.nps.edu/bitstream/ha...12/48_Kirk.pdf
Old 12-14-2017, 02:34 PM
Interesting reading for sure, but I suspect that the minimum tube count record holder might be the RCA 8PT 70xx series... 10 tubes plus CRT, no transistors, no compactrons, but uses 4 ss diodes and Selenium rectifiers. Perhaps Muntz beat that, I don't know.
