Identify transformer
This transformer part number 7986-167-300 with date code
7248 so 1972. Is that Magnavox type part number? Eia code 549 midwest coil and transformer. Looks like audio output transformer, like the ones 5 tube radio has. Searching web simular came up as vertical blocking transformer I thought sams Photofacts had a way to look up by part number.I did see they have it for Ics lookup. I don't have any other sources. Tried searching on encompass no luck.maybe to old. Thanks Doug |
What exactly is this in & what is its function ???
Maggy part number style is ######-## example 703744-03 ( or just -3) is a power supply for a T991 chassis. Also I dont think vert blocking xforms were used since the 1950's. 73 Zeno ![]() LFOD ! |
It's something I had.
Just trying to figure what it is. |
Roger that. It does look like an audio out. Anything else wouldnt have the plug in terminals. It would probably sub any tube type class A amp of low power.
The ##s on it dont ring any bells as far as format goes. Could be in house markings or one of the small mfgrs numbers. |
Maybe Warwick or something of that time.
In house number is what I thought also Thanks for the info |
Most audio output transformers use red and blue for the primary wire color. I've seen similar looking transformers with black wires used as pilot lamp or filament supplies.
So using a audio generator input and scope output would I be able to tell if it's audio tranformer
Or ac transformer ? Audio transformer maybe range of 50-10k And ac power transformer limited range? I can come up with the ratio the the gen and scope. Might give an idea if it's 10:1 possible 12v, 20:1 possible 6v |
It looks too tiny to power much of anything.
If it's a power transformer for 120V line to B+, turns ratio (Vin:Vout) might be around 1:2. If it's a filament transformer, ratio would be around 120:6 or 120:12 (20:1 or 10:1) Audio transformer turns ratio might be around 20:1 (Vin:Vout) but wider possibilities than a filament transformer. The lugs seem useful for speaker connections rather than circuit connections. Last edited by old_tv_nut; 12-02-2021 at 08:34 PM. |
It's the little power transformer used in my Magnavox T940 combo set for the turntable well lights, 6.3V at about 100ma located on the front of the TV chassis and feeds a little pop up switch. They spared no expense.
