Ivc ~ ivc-871p ~ 1" video recorder service manual
Greetings!
I am new to the forum (or any forums), so bear with me if I’m a bit lost…. I have acquired an IVC 871P (PAL) open reel colour video recorder from about 1972 (pictured) & although been sitting in a cupboard for the last 35years unused, I was very surprised to find that it still worked with decent picture! However it was very noisy as the bearings are all pretty dry of lubrication, so I set about removing all 4 motors & have re-lubricated the bearings along with any other pivoting points, guides etc. It’s a lot better now but the bearings in the scanner drum still need attending – I dernt attempt to remove & dismantle it without some kind of service information, which is my main issue. That is what brought me here really – does anyone on here know where I may get a paper copy or scan of a service manual for the IVC 871P video recorder, especially the scanner drum & electrical schematics / setup procedures? They are so old that I can’t find anything on the usual internet search etc. Also does anyone have a pinch roller for one of these machines – it’s about 30x19mm with ¼” shaft size, though that’s unimportant as can be modified to suit. Cheers, Mark Barry… |
Greetings!
If no one on here knows I'd check with Richard of labguysworld.com he'd be one of the more likely people to have service literature.
Thanks Electronic-M,
I will certainly try to contact him as noticed his site before. I've been using the machine a lot & am starting to get some white 'comets' all over the image, so fear the video head is on it's last legs - although they just slot in from above, I doub't anyone has one! Maybe it's now just an ornament - shame.... Cheers, Mark... |
The last one I saw was at WCIV. They used it to delay the GONG SHOW.
Those are type A machines (alpha wrap). They have a tension servo to control skew. Head switching occurs at the bottom of the picture unlike type C machines (omega wrap) where it occurs on the inactive lines in the vertical interval. The real pitfall was the time base corrector. At the time TBC's were not very good. They had maybe one line of correction. They used glass delay lines rather than digital techniques to control off-tape error. There was a station in Columbia SC who had the IVC automation system. It was 6 decks in a console which would play back-to-back commercials. It worked pretty good but the technician had to be pretty nimble on his feet when there were 10 second spots in the break! At another station I worked at across town, they had IVC500 studio cameras.
"A" is usually used to refer to the Ampex 5000 and 7000 series machines, not the IVC. These Ampex VTRs have the same drum size and video track layout as C format. The A and C machines all have alpha wrap. Many years ago I put a tape recorded on an Ampex 7003 on a C format machine. It sort-of worked. Since there are almost no working A format machines in existence it should be possible to modify a C format machine to play A format tapes.
The IVC 1" machines are very different. Omega wrap, smaller drum. For completeness, B format was a Bosch 1" machine with segmented helical scan. Very good pictures but never really caught on because it couldn't do the "stunt" modes of the C format. Last edited by ppppenguin; 06-11-2022 at 01:09 AM. |
