Old 06-21-2023, 02:17 PM
Tony58 Tony58 is offline
Panasonic AG-7350 Playback Problems PAL & NTSC
Hey guys,
i have a Panasonic AG-7350 video recorder here.
The video recorder does not show a good picture when playing a Pal cassette, and the tracking is not good either.
The sound works on normal as well as on HI-FI.
When playing NTSC cassettes, the picture and tracking is significantly better, but the picture is still not clean.
Here is a video for more details.
https://youtu.be/4RZ2KgMy_d8
I have already replaced a few capacitors based on this YouTube video.
https://youtu.be/oJLEtmANGIA
Unfortunately unsuccessful so far.
Maybe someone has an idea what could be the problem.
Greetings
Old 06-24-2023, 02:40 AM
Retired Batwings Tech
It's not a multi standard machine, you can't play a PAL/SECAM tape in an NTSC machine and expect it to work correctly. 7350P is the PAL format model and neither will play a LP or SLP recorded tape, it's SP only.
Old 06-25-2023, 04:49 AM
djski djski is offline
His NTSC model will play 6 hour recordings with normal audio.
Old 06-25-2023, 04:12 PM
As far as I know, P is the NTSC model and E is the Pal model. My recorder is an AG-7350E wich is PAL.
Old 06-26-2023, 05:14 AM
A lot of speculation could have been avoided if you originally stated you had an AG7350"E" going back to your 6/21 post.
Old 06-25-2023, 08:15 PM
So explain to me how a PAL deck plays an NTSC tape better than it's native format?
Old 06-26-2023, 04:54 AM
Thats what I asked, thats why I started this post.
Here is a picture from the user manual.
You can set the recorder whether you want to watch PAL or NTSC tapes.
Old 06-27-2023, 09:02 AM
Don't recall seeing this function on my old 7350... one caveat, NTSC 4.43 is not the same as the common NTSC which is 3.58. 4.43 is the colorburst frequency which is common across the pond and not compatible with tapes recorded in the states.
