Old 08-03-2024, 04:58 PM
Mr.Duncan Mr.Duncan is offline
Duncan's 1960 Magnavox
Picked up this beautiful 1960 Magnavox Console.
I've restored a few vintage tube radios in my past, but never a TV before!
Everything, and I mean EVERYTHING appears to be original and untouched.
A few tubes have been replaced with GE units, and the 5U4GB is labeled "Japan"
I'm still learning here on my end, so any helpful advice, corrections, or input is always welcome!
A quick power up shows a decent picture!
I'm re-capping this set because the C2 4 section capacitor did blow out (overheated, swelled up, and popped) - causing loss of picture. The whole process took 2 seconds, and I shut the set off while the cap popped.
Year: 1960
Model # 1MV354 R
Chassis: V30-15-00
Old 08-03-2024, 05:10 PM
Some photos of the unit below:
PXL_20240720_162133024 by Thomas Duncan, on Flickr
PXL_20240720_164751604 by Thomas Duncan, on Flickr
PXL_20240720_164740585 by Thomas Duncan, on Flickr
PXL_20240720_163335964 by Thomas Duncan, on Flickr
night photo by Thomas Duncan, on Flickr
PXL_20240722_011714175 by Thomas Duncan, on Flickr
262429057_7107277319290335_6646583959770188826_n by Thomas Duncan, on Flickr
Old 08-03-2024, 05:15 PM
Retired Batwings Tech
Dude that thing is a real time capsule, all I can say is WOW! Very nice catch.
Old 08-03-2024, 05:18 PM
Thank you! I will take good care of it.
Old 08-03-2024, 05:25 PM
Recap amp
I started with replacing all the wax/paper capacitors & large 4 section capacitor in the audio amp.
I used slightly higher rated film caps inside the chassis (factory is 400v, I used 630v)
As I understand film caps are not polarity senstive and can be installed in any direction.
Multi-section can cap was replaced with a unit from Hayseed.
Re-installed the amp and everything still worked great!
PXL_20240722_210024262 by Thomas Duncan, on Flickr
PXL_20240722_210111542 by Thomas Duncan, on Flickr
PXL_20240722_211318305 by Thomas Duncan, on Flickr
New film caps (yellow)
received_2499329160274717 by Thomas Duncan, on Flickr
PXL_20240726_223320695 by Thomas Duncan, on Flickr
Old 08-03-2024, 05:34 PM
Removing TV chassis
I wore 15,000 volt gloves, and safety discharged the high voltage lead on the CRT.
I then removed the TV chassis for inspection.
The flyback transformer looks a little melty. Some of the wax fell off / melted off. I don't see any signs of arcing inside the metal case of it.
I contacted Moyer for a replacement / spare and had no luck.
If anyone has a good used / NOS one let me know! - I'm looking into how to re-coat the flyback?
Flyback Part#: 360779-1
Other part #s:
Merit HVO-172
Thordarson FLY-179
PXL_20240723_230154818 by Thomas Duncan, on Flickr
PXL_20240723_232412518 by Thomas Duncan, on Flickr
PXL_20240723_232419443 by Thomas Duncan, on Flickr
PXL_20240723_232757786 by Thomas Duncan, on Flickr
PXL_20240724_204340786 by Thomas Duncan, on Flickr
PXL_20240724_204344225 by Thomas Duncan, on Flickr
PXL_20240725_011805289 by Thomas Duncan, on Flickr
PXL_20240725_011814477 by Thomas Duncan, on Flickr
Old 08-03-2024, 05:38 PM
TV chassis re-cap
I removed each paper/wax cap and started replacing them with film caps.
Again, I heard and read the diagrams online, it seems these yellow film caps are not polarity sensitive?
Most of the caps were rated to 400v, the replacement caps I used were around 600-630v. Same uF factory rating with a tolerance +/- 10%
PXL_20240730_204949224 by Thomas Duncan, on Flickr
PXL_20240801_010015986 by Thomas Duncan, on Flickr
PXL_20240801_010041094 by Thomas Duncan, on Flickr
Old 08-03-2024, 09:20 PM
Very Nice TV! My Parents has a set like that - but only a tv. I spent many many nights
in front of it as a kid.... Watched till the stations went off the air at 3AM.
I would like a parts store like that near me......
Old 08-03-2024, 10:29 PM
Only lytics and IIRC Tantalums are polarized.
Your flyback is probably fine if it makes the screen light up that well. Many flys would normally drip some wax or tar (depending on what they're made of) over the course of their service life....It's also not uncommon for some of the tar to chip or peel off with age....the flyback doesn't need replaced it just needs recoating with wax, tar, corona dope or sensor safe RTV (which one is a matter of personal preference).
The positive grounded lytic probably filters a negative voltage rail. All tube gear has positive rails, but some have negative rails too. Some sets connect the can lytic capacitor negatives to a floating negative rail separate from the chassis, and if you change that bad results tend to occur. Another thing that can be confusing when you see it for the first time is a voltage doubler circuit.
Don't replace paper caps with ceramics in TVs, ceramics aren't stable enough for video and sweep applications that originally called for paper.
Old 08-04-2024, 08:04 AM
Thank you for the info, I'll keep that in mind. I didn't know that about ceramics.
I'll pickup some blue sensor safe RTV from the store this weekend.
Out of the TV Chassis capacitors I replaced so far:
13 replaced with Film caps
1 with a Lyitic
2 with Mica (Hard to find value & tolerance) - Mica seems to be okay? - From what I can find online its not considered a ceramic.
.0039 uF @ 200v +/- 10% (Part of the Horizontal Hold Circuit)
.0051 uF @ 400v +/- 5% (Sits between the Sync Phase inv & AGC Clamper)
Old 08-04-2024, 05:24 PM
Micas are fine...expensive, but fine. Those 2 caps you changed should also be available as film capacitors (I don't think I've seen 5100pF used anywhere before and haven't looked for new parts that value) and I probably would have used Panasonic or Illinois Capacitor brand red film caps in those locations for budget reasons.
Old 08-05-2024, 09:08 AM
RTV for Flyback
After reading multiple forum posts about re-coating the flyback, i've settled on the following RTV.
Brand name: Momentive / SNAPSIL
Model RTV: RTV-133 Silicone Rubber
It's been reported good to use on flyback transformers, and carries the following traits:
  • It does not produce acetic Acid .
  • It utilizes an atomospheric moisture cure system, which releases an
    alcohol vapor from the sealant surface during cure.
  • Dielectric Strength: 20kv per 1mm layer.
I've got a MSDS sheet listed here for more reading/ spec.
Old 08-05-2024, 10:14 PM
The new can caps arrived from hayseed.
I installed one, and have one left to replace.
That just about does it for all the capacitor replacements.
The old can cap that was replaced was VERY leaky and way out of spec. It was reading 80-100% higher uF ratings than listed on the can.
PXL_20240806_020045066 by Thomas Duncan, on Flickr
PXL_20240806_020145917 by Thomas Duncan, on Flickr
PXL_20240806_025948971 by Thomas Duncan, on Flickr
PXL_20240806_030359626 by Thomas Duncan, on Flickr
Duncan
Houston, TX
1960 Magnavox
Old 08-06-2024, 06:21 PM
Today's the day!
Finished replacing the last multi sectional capacitor.
The old one was VERY swollen and leaking fluid.
I powered the set up slowly with a variac.
At full voltage I'm pulling 2.5 amps which seems to be normal. No abnormal sounds, no arcs.
The photo below kind of exaggerates how bright the tube filaments are glowing. Much more mellow in person.
I'm getting just a non-adjustable horizontal line across the screen.
So I'll need to do some reading as I have no clue what controls the vertical movement of this line?
**I only ran the set for about 30 seconds with the screen set to minimum brightness** - didn't want to burn the CRT.
PXL_20240806_221113960.PORTRAIT by Thomas Duncan, on Flickr
PXL_20240806_225509131 by Thomas Duncan, on Flickr
PXL_20240806_230959278 by Thomas Duncan, on Flickr
PXL_20240806_230953330 by Thomas Duncan, on Flickr
The safety glass in the display makes the line look much thicker than in person.
PXL_20240806_225528496 by Thomas Duncan, on Flickr
Duncan
Houston, TX
1960 Magnavox
Old 08-06-2024, 06:47 PM
Upon checking both these tubes, one BARELY shows good on my tube tester.
6BF6 - Pass
Vert OSC & AGC
6DT5 - Fail? - Readings are poor.
- Labeled as VERT output.
Photo of 6DT5 test below.
PXL_20240806_234132521 by Thomas Duncan, on Flickr
PXL_20240722_010820973 by Thomas Duncan, on Flickr
Duncan
Houston, TX
1960 Magnavox
