Old 08-16-2016, 01:50 PM
ed857 ed857 is offline
21EP4B sub for 21YP4
Hi all
I have a Philco with a weak 21YP4 CRT. I also have a NOS 21EP4B rebuild.
Will the 21EP4B sub for the 21YP4? The bulbs sure look the same.
Thanks,
Ed
Old 08-16-2016, 02:01 PM
Originally Posted by ed857 View Post
Hi all
Thanks,
Ed
The 21EP4 CRT is a magnetically focused, cylindrically faced CRT. The 21YP4 is an electrostaticly focused, spherically faced CRT. To use the 21E as a sub, a magnetic focalizer, would have to be fitted, but the CRT face would not match the mask opening.
Old 08-16-2016, 02:11 PM
Well.............Rats
Thanks for the reply
Ed
Old 08-16-2016, 02:58 PM
I've got a spare PM focus unit off of a large neck Philco CRT, and I've put tubes with different face curves in other tubes mounts successfully. It could work...The edges of the mask won't fit the screen in as visually pleasing a manner as the original though...
If the original ain't watchable with a brightener, may as well try the swap....
Old 09-03-2016, 10:25 PM
Robert Grant's Avatar
Robert Grant Robert Grant is offline
You're not thinking of the 21AEP4, are you? (That would be a sub for a 21Y, and saves you the bother of aligning the ion trap).
