CTC 11 Static Convergence
I've been practicing setting up the convergence on my 11 and I have a question for you color roundie gurus: What does it indicate when the center is fairly well converged but you get a red and green dot on opposing sides of the vertical white line? When I have dots displayed on the screen the red and green dots disappear( they only show when I display a crosshatch).
On closer examination they appear to follow the vertical retrace, I guess? And there are blue dots in there too.
A closer look.
A very interesting phenomenon. Might try slightly turning down the G2's. Looks like retrace lines trying to form. None of my TV's have ever done this, so I really don't know. Here's my CTC-11 after as thorough a convergence job as I coukd muster.
"If you wish to make an apple pie from scratch, you must first invent the universe." -Carl Sagan |
I've seen a number of test generators do that problem. I guess it's digital noise from the synthesizer circuitry bleeding into the output.
Kevin, if you want to try a test pattern DVD I can send you a copy.....let me know.
"Restoring a tube TV is like going to war. A color one is like a land war in Asia." |
I have one, thanks!
Kevin,
Those things were usually a bear to converge back in the 60's. They don't get any better with age. So don't feel too bad. Looking at the first picture I’d say adjust the blue lateral. But after looking at the next picture that wouldn’t help much. The dynamic convergence is off. Check the rectifiers and other components on the board. You might try rotating the assembly. It might make a marginal difference. Maybe Just be aware that converging sets is a lesson in compromise. Some think that near perfect convergence can be obtained on those sets. Never have and never will. Adjust for the best overall convergence. My advice is to enjoy the picture. It's amazing how fast you lose track of the convergence. Good luck and have fun. Phil Last edited by reeferman; 04-08-2017 at 01:10 AM. Reason: brain fart |
listen to reeferman.perfect convergence is a myth.rarely seen.get it as close as you can and stop.my main job back in the shop was to rebuild tuners and setup the convergence.i learned very quickly that close was best.the older the set,the harder to set up.
It's definitely video pulses during vert retrace. During retrace, the dynamic convergence waveforms can be wildly different, and it is meaningless because there is not supposed to be any video there! Blame it on the generator, not the TV, and don't worry about it if there are no retrace lines on real video.
Thanks for the replies. It does appear to be generator related, because I don't see it with my DVD crosshatch pattern. I thought possibly the color killer threshold would have some influence, but that didn't help at all. Anyhow I have the dynamic pretty well dialed in now other than one small area on the far upper right edge. There's simply no way to adjust for an unruly small area without messing up the overall bigger picture. But once you start watching a movie you pretty much forget about the outer edges. I'll post some more pictures when I get a chance.
The dots are simply the generator cross hatch extending into the vertical blanking interval. The red, blue and green dots do not converge during retrace.
Try looking at the vertical blanking interval on a scope and you will see what I mean. |
