Old 10-04-2025, 05:35 PM
Chris K Chris K is offline
Philco 19" Briefcase Model...Probably Tube Socket
I was troubleshooting an audio issue with a couple of tube pin test sockets and now, I have an intermittent heater filament issue in this series string set. Probably cracked a joint somewhere under the sound IF circuit board. I hate taking these things out for reasons everyone knows all too well. These are identical to the Seventeener correct except for a bigger CRT screen and a smaller bezel? I can't remember if I can get access to the bottom of the sound IF board if I remove the CRT but that would be preferable to keeping track of a dozen wire stakes and the ground tabs that need to be de-soldered and bent apart. This thing was all but there. Probably self-inflicted with some cheap build quality to help it along.
Old 10-04-2025, 10:08 PM
damen's Avatar
damen damen is offline
Looking at the Sams Photofact for the 11H and 11J briefcase 19 sets, it does not appear that the chassis has cut-outs to access the bottom of the boards.
Old 10-05-2025, 07:32 AM
Yeah I think I’ll have to go through the series string and check continuity. I’ve looked at the tubes and they are fine.
Old 10-08-2025, 05:14 PM
Was preparing to test the string tube to tube continuity and noticed a broken solder joint between a wire and a post on the top of the sound board labeled "Fil". Need to start checking the more obvious possibilities before imagining the more disastrous fails. TV back to working condition.
