Old 01-12-2013, 02:43 AM
jmm83 jmm83 is offline
Sharp VC-682U VCR
Hi
can any one tell me where the mode switch is located in this vcr
i think i need a new one or it needs to be cleaned because when i hit fast fwd it will rew. or when i hit stop it will eject
Old 01-12-2013, 09:59 PM
Labrat
Guest
Posts: n/a
Hi. I have just looked at the schematic for that model, and almost certainly, the fault is caused by a high resistance switch on the front control panel Panel H. The switches form part of a voltage divider chain, and if a switch goes faulty, the wrong command is received.
I can send the schematic if required.
Wayne
Old 01-12-2013, 11:36 PM
ok that would be great can you tell me what the switch looks like
Old 01-13-2013, 01:44 AM
Labrat
Guest
Posts: n/a
The switches are the ones directly behind the plastic push buttons for FF REW STOP and so on. I would replace all of them. Thew are listed on the board as position number SW8101 through to SW8108
Wayne
Old 01-13-2013, 02:59 PM
oh ok so you mean the micro switches. i did find where the mode switch was & i did clean it. it seems to work better now but the stop button still ejects the tape sometimes
Old 02-24-2013, 06:34 PM
waltchan waltchan is offline
Switches were fairly common problem on these early-90s Sharp VCRs, either they were dirty and not taken care of, or they were pressed down too hard by the previous owner.
Press the same button hard for more than 100 times non-stop usually fix the problem. Many times, keep pressing the same button repeatedly will often fix itself and increase its contact level.
