I may need a custom screw machined
So I was working on my Norelco Continental 300 tape recorder today, took out a screw that holds the oil wick for the bottom flywheel bearing, and the darn thing snapped in half when I was screwing it back in. Near as I can tell, it's pot metal that weakened over time. It's not a hugely complicated part, and I'm attempting to JB weld it back together considering it was a fairly clean break, but if that fails I need to replace it. This is kind of an oddball piece; the thread itself should be standard, but it's more of a hollow cylinder with a single flathead hole on the bottom.
Does anyone have access to or can recommend someone to custom machine a new part? This has been a long restoration job, and I'd hate to lose it to an unobtanium part right at the end.
To keep your tubes running smoothly, make sure to dust underneath the glass as well. |
A hollow cylinder with a single flathead hole on the bottom.
A single hole for a flathead screw, maybe? As in, countersunk? A pic or drawing would really help here. Plus an idea of whether you think it can be made by modifying an existing item, like a threaded bushing. Chip |
I'll get pics tomorrow, once the JB weld is done and I've tested it.
If it helps, it's a hollow core, one end open, the other end closed with a sunken flathead grip. I think I could possibly modify an existing metric screw to do what I need, but I'm a hair concerned about trying to hollow one out to hold the material.
My repair failed. I'm at a loss. I went out and got some screws that match, so I can at least get a part in there, but I'm not sure what to do about the little black plastic (?) cap. Does anyone have a source for a machine shop or someone who can take my part and repair/replicate it?
That doesn't surprise me, I've used that sort of thing before without success.
Anyway, that looks easy enough to duplicate, it isn't a far cry from an ordinary set screw. I would use a couple of nuts at the top to help lock one into position in a vise, cut it to size and file the threads off the end, then just use a drill press (if I had one) to drill the hole I want. I'd measure the drill bit first and put tape on it in lieu of a depth gauge. |
I do some machining. I've got a lathe. You could either take several measurements, like thread and length, etc. or send it to me to duplicate. Probably wouldn't cost much more than the postage. I'd start out with a commercial bolt if I could just to avoid cutting the threads.
Ok, so, I may have found a solution to this. If I'm wrong, I'd like to pursue getting the part machined.
Turns out this actually is a standard part, it's just not that common. It's called an extended tip set screw. https://www.mcmaster.com/#set-screws/=17td1yk I've ordered some (box of 100 for 6 dollars, so let's hope I'm right) and at least know the threading and diameter will be correct. Right now my only concern is that the tip on the broken part is a sort of black plastic, while the newer one appears to be all steel. Maybe that's just a matter of improved design, but I suppose I'll find out. Anyway, thanks for the help. I'll update once the part comes in, and will potentially reach out for help should I need the replication. I still have the broken piece, so I'll be able to keep it as an example.
Also look at the nylon-tipped stainless steel set screws. They are
wonderful things, I used hundreds in my work holding in expensive laser mirrors. I never chipped one! |
Well, lucky me, the new screws worked.
Here's my now repaired Norelco Continental 300 next to my next project, a 1960s GE Toast R Oven Thanks to everyone that helped me out!
