1978 RCA Selectavision VCT200 top loading vcr not going into play
Pulled this out the other day and I'd like to get it running but all it does is rewind and fast forward. Pressing play starts a sound you can hear down inside but the two arms that take the tape up around the drum won't move. I found that I was able to move them up forward myself but I don't think they should be able to move that freely. Doing this did start some rotation and belts spinning but that's it. All belts are good. Any ideas on where to start on this. I would tear down to those arms but I would need some kind of steps. There's metal and screws everywhere down there. Assuming these arms have detached from something.
Genesis does what Nintendon't Last edited by pac.attack76; 11-29-2017 at 11:36 AM. |
Hi. Your problem is either a broken loading belt or the loading gear has split in half. Remove the bottom cover and unscrew the 4 circuit boards to reveal the mechanism. The boards open in hinges for ease of service. I have attatched a pic of the loading motor and gear.
Regards, Fivos Last edited by djfivos; 11-28-2017 at 11:56 AM. |
Genesis does what Nintendon't |
Here's how mine looks.
Genesis does what Nintendon't Last edited by pac.attack76; 04-19-2024 at 09:19 AM. |
Well, that looks OK. Does the loading motor turn when you press play? Maybe the belt is slipping...
I'm looking at it right now. Everything turns but if I run it upright, I hear a scraping. I flipped it over and found that white plastic gear is sliding down and touching the metal round piece that always spins that turns the heads (drum). The gear turns for a bit then shuts off. I don't thing its attached the the arms up above anymore.
I just watched this video and on his machine, the gear that's above the chassis broke in two pieces. Maybe that's the case with yours too. Unscrew the loading gear assembly and take a look there.
https://www.youtube.com/watch?v=koJJf-N0JAY |
I have the Panasonic version of that VCR but I don't have access to it right now. The screws are shown in the video I linked previously.
Yeah I tend not to watch them due to the constant buffering with my current internet. I went ahead and checked this out. Silicon valley and he didn't even have any tools, geez! Funny how he removed the tape cover when it wasn't necessary. He ended up taking everything down from the bottom. Glad I don't have to do it from the top. I was surprised he glued it since that rarely ever works. Video was too dark to see what screws were removed. He did it too fast and didn't even a how which ones. I may be able to figure it out. 3d printing doesn't help me here tho as I do not have access to something like that and who knows how much it would cost to have someone do that. No name or part number to go by either. Just a gear. If I knew what to order, maybe I could find a replacement.
Well, thanks to your help and some idea from the video, I figured remove screws to move drum out of way, two screws holding the motor/gear assembly and unplug the 3 wire plug and pull out revealing the same problem. I circled the broken gear and location where it attaches. Is there a name or part number for this gear I can use to search?
Good luck Buddy
No, the gear underneath split in half so it won't load plus the dew indicator led is on now so it won't do anything.
I need another one badly but not sure where to turn. Can 3d printing really make another one?
