Hi
Hi,
Just saying hello - big Predicta fan - I just finished restoring a Predicta Siesta, my first TV repair! |
Sounds great! Welcome!
Welcome to VK and congratulations on the Predicta
Hi Judge,
Tell us more about your Siesta repair. I did a Holiday for my first TV and it was a journey. Never would have gotten it running without the folks on this site. |
So then I re-attached all the wires, powered it up and there was no video and the sound was always at full volume. Someone from ARF ('analog.tv') helped me figure out that there was no horizontal oscillation, which I tracked down to a bad couplate. I replaced it with the old one and everything was good - apart from the sound. I left everything out on the bench until I got a replacement couplate from Crist. I didn't really fix the sound until I was putting everything back together - I had re-attached one of the 50 wires to the wrong point! I also detached a power lead from the clock switch while I was putting it all back together. So I had to take it all out again to re-attach that lead to the clock properly. BTW here is a video.
http://nixies.us/ Last edited by judge; 12-13-2018 at 04:59 PM. |
Hi! Always nice to see a new member!
Predictas are adorable, congrats on successful restoration! What is a couplate? A hybrid network on a small separate board?
To understand a bygone era, you should use things from it |
PCB based sets tended to be heavier users of couplates.
Welcome aboard!
Let me live in the house beside the road and be a friend to man. |
Welcome aboard! You've come to the right place.
Looks like you can fix anything. Good show!
Rick (Sparks) Ethridge |
Glad you're here!
Ham shack...AM side: Knight-Kit T-60, RME-45 Vintage SSB side: National 200 Modern SSB: Kenwood TS-180S MFJ tuner, 130' dipole |
Thanks for the explanation! I remember that I've met 'couplates' restoring a Dynaco FM-3 tuner. They were responsible for de-emphasis there, so I had to replace them by some crafted networks recalculated for the European time constant.
