Old 10-08-2025, 06:21 PM
pac.attack76's Avatar
Stuck in the past
2011 Panasonic Viera TC-P50X3 50" plasma dead
No power at all. Removed back and metered both fuses and beeps on both. Do these have to be removed to test or is there something else I need to be looking at? No bulging caps.
Genesis does what Nintendon't
Old 10-12-2025, 07:42 AM
Stuck in the past
I did also notice when plugging into outlet, there's a relay click but no lights or power.
Old 10-12-2025, 10:28 AM
kf4rca kf4rca is offline
Check the Mosfets in the PS for short.
Old 10-12-2025, 10:34 AM
Stuck in the past
Ok, thanks!
Old 11-03-2025, 08:38 AM
Stuck in the past
Only time I've ever had dealing with mosfets was in an xbox 360. Im a bit confused as I tested what I thought were mosfets but the only one that beeped on the multimeter was actually a shottky barrier diode. What should I be looking for on here? I think I'm missing something 😕
Old 11-04-2025, 07:01 AM
Probably it will have a permanent resistive load in the PSU (but only older PSU's have it), then the solution for testing is desoldering. Or, is a special MOSFET with a Schottky diode in antiparallel, normally used for syncronous rectifying.
Old 11-04-2025, 07:47 AM
Stuck in the past
So I should take it off the heat sink and remove from board before testing? It's a YG862C15.
Old 11-05-2025, 06:16 AM
According with the data, is simply a Schottky diode. But in doubt, desolder some terminal, or remove them. To be sure if is not a subsequent circuit having trouble (like a post buck regulator going do-do).
