Old 10-24-2009, 08:46 PM
Kalamazoo-DJ's Avatar
Kalamazoo-DJ Kalamazoo-DJ is offline
Huge magnavox Combo roundie Warren MI
I own that as of today, it was tested by a fellow smarter than me, he said it has a bad thermistor and a weak green and blue, but can be brought back up slowly.
The player works and the radio did tune in when I got it home, however there is no sound in any mode, first of all where should I begin in this process of restoration?
Old 10-24-2009, 08:53 PM
radio tuned it based on the tuning meter?
Old 10-24-2009, 08:54 PM
does it have a remote, look on the back for a large metal switch
Old 10-24-2009, 08:55 PM
on more what is your experience level in electronics?
Yes it was moving and stabilizing as I moved the tuner on stations in my area and some I know where in Indiana as well it was able to pick up on the dial
Old 10-24-2009, 08:56 PM
yes it does have the switch, there are two of them
Old 10-24-2009, 08:57 PM
make sure you have the remote off.
Old 10-24-2009, 08:58 PM
speaker switch to internal
modern electronics fair to average this old stuff I know where the on off switch is lol and I do know basics
Old 10-24-2009, 08:59 PM
ok it is on internal and I can hear scratching sounds out of the speakers when I adjust volume but no output sound
Old 10-24-2009, 09:02 PM
pm me with your phone and I will call you gotta go off line for a bit but can talk
Old 10-24-2009, 09:06 PM
make sure your not on stereo, that is phono, select fm mpx
Old 10-24-2009, 09:11 PM
ok I sent my phone number to you I will check my settings
Old 10-24-2009, 11:30 PM
Can any one point out?
I have some pictures the thermistor is suspected bad where do I find it and how can I tell?
Old 10-25-2009, 07:27 AM
not on those pics, those look like signal pc boards. FYI I did see at least one likely electrolytic caps on one of those board that prob should be replaced. It looks like a paper tube on laying on the side, about 1.5 inch long and .75 inch wide. should have a + marking on it some where. Any of those are suspect.
if they leak they can throw off the tube bias and cause the tubes to pull too much current. you will need to locate and replace all of them. A Sams will help you find all the parts.
Maybe some more pics of the rest of the chassis.
