Hello again.
Thought I would share another VCR that I salvaged from the crusher awhile back. My initial plan for this Toshiba VCR when i first acquired it, was to simply take the supply reel back tension band and use it for another project I am working on and then just junk this VCR. Since the belt wouldn't work with my other VCR, I was stuck with what to do with this Toshiba, since I never intended to fix/ use it. I did notice that it had been serviced at one point *part of the reason I took it* but when I tried to play a tape the roller guides would not engage the roller guide track to the head turns out the loading motor belt was worn out, no biggie just replaced with a elastic band and TADA! back from the dead Seriously I have to really admire you guys who worked on these all day, I think I would have been tearing my hair out like Homer Simpson from frustration Anyway it's all good now. So i present to you my 1987 Toshiba Model V-1200C.
Forgot to ask what the STD, HRC, IRC, OSD and CFM stand/used for.
OSD--On Screen Display
CFM--Confirm (used to confirm program settings) No idea on the other ones.. VCR repairs "back in the day" were 90% mechanical. Worn/slipping/broken belts. Idler tires/clutches, or damaged front loading mechanisms. Lots of dirty/damaged video heads from playing creased/poorly spliced rental tapes. Early VHS units used incandescent bulbs for the tape end sensors, and the bulb would burn out causing the unit to lock itself out to prevent tape damage. Main electrical problems I saw were Panasonics (PV-1225 and others) with burned up SMPS. Most units used linear supplies, which were usually pretty reliable. Now, of course, these things are getting into the age where leaky or dried up caps start to become an issue. Last edited by N2IXK; 09-12-2014 at 08:00 PM. |
STD (standard), HRC, and IRC are three different standards for cable-TV channel numbering and frequencies. You will see them on many "cable-ready" TV sets and VCRs.
very nice
____________________________ ........RGBRGBRGB ...colour my world |
IRC Incrementally Related Carrier, HRC Harmonic Related Carrier, two obsolete cable channel methods. STD is standard broadcast.
OSD is On Screen display. Not familiar or more likely not recalling what CFM is, maybe a Toshiba thing. |
Very nice my friend....Im glad a rubber band helped ya
Did Toshiba always build their VCR's, or were they outsourced in later years? I have a new-in-box Toshiba W-612 hi-fi VCR I purchased more than 10 years ago as a spare, but never used. I was just curious if it is worthy of keeping or if it's an outsourced Funai or Orion junker.
I've had good success with Orion-built Toshiba products. They seem to be a lot better, than the last of the Panasonic VCR's. I won't touch one of them. From a firm, that built one of the best VCR's, to the poorest excuses of a VCR. |
On the older Toshibas, the most common problem was a failed loading motor. If it did fail, you would hear a big crunchy noise or no movement at all due to broken bearings inside the motor.
But despite that, Consumer Reports rated Toshiba as the second most-reliable VCR brand after Panasonic. Toshiba was considered a "Honda" like brand back in 1980s with Panasonic closer to "Toyota". Last edited by waltchan; 10-12-2014 at 12:08 PM. |
Thanks for the info, waltchan! Appreciate your help!
