found a 1960s Philco Portable TV today at the Antique Mall!
Hello Everyone, today I was browsing at one of the local antique malls and I was browsing through the booths and sure enough in the 3rd to the last booth in the store I find for $15 a 1960s vintage Philco 19" portable B&W TV that I picked up and brought home as a possible future project. As soon as I got home I plugged the set in and turned it on the TV came right up like it was supposed to with exception to a horizontal line in the middle of the screen (I have a picture of what the TV is doing) I kind of suspect that its a vertical stage issue (e.g. bad vertical amp tube or something like that) but from what little I could see of the picture tube in its fully collapsed state it looked pretty bright yet like it might of been a low hours set (the cabinet is in near mint condition as well except a little wear around the VHF tuning knob) other than that the original bunny ears are still intact not broken, and the cabinet is nearly flawless minus the yellowing of the plastic.
I have pictures of the unit and also I noticed that its a slim-line model (its less than a foot deep as can be seen in the pictures.) Any help, advice or information about this TV would be wonderful. Thanks, Levi UDATE: I opened the back of this TV Set and apparently this TV has never been opened as it still had all of its original Philco branded tubes in the set yet. I checked the 6FD7 tube that operates the Vertical amp and vertical output stage of the TV and sure enough it tested completely dead on the tube tester, and when I looked at the getter material, it was completely gone, as it had apparently gone to air at some point in time (there was a faint white outline where the getter material used to be.) SO I think this is why the TV had no vertical deflection. Its a cold chassis design that utilizes a 6BQ5 tube for the audio output stage and has the option for a remote control (has markings moulded into the back cover that says something about a remote control switch of some sort (which isn't there in this case.) Apparently this was a higher end set for the time period? Last edited by Captainclock; 12-05-2015 at 03:55 PM. |
Turn the brightness down or you will burn that line into the phosphors permanently! The reason that line is so bright is that the energy that would be dispersed over 525 lines is being concentrated on only one....The phosphor is not meant to handle that much energy hitting it! Turn the brightness all the way down (if that extinguishes the line turn it back up until the line is visible again but dim) until you fix the vertical.
Even weak tubes can produce a bright line, you will know it is a good tube once you fix the vertical. Tubes can be an issue, but bad capacitors, and resistors are a more common cause of vertical deflection failure....I hope the vertical output transformer and yoke are good, they are not the most common cause of that type of failure, but still a possible cause, and often hard to get replacements for in many sets.
A COLD set? how about a picture of the chassis?
Always be humble, and never think too highly of your self or your knowledge, because the moment you forget that there is always someone somewhere that will knock you off your perch/poke a hole in your ego, (and those that can and would help you, won't bother)....That is a lesson I've learned the hard way.
There are a lot of people here who know a lot more than you, or I, do, about television repair. Getting a Setchell Carlson going that was previously restored, with a few tweaks, was a good thing. Here, you will find that humility, patience, and the willingness to learn will go quite far. That said, chill out, and let's put this train back on the rails.
"Restoring a tube TV is like going to war. A color one is like a land war in Asia." |
Some CRTs (non-aluminized and projection tubes especially) will burn in under 30 seconds, especially if the HV is over 18KV and the gun is biased for high beam current.......High enough beam current and you can burn that line in to the face in under a second....It is hard to tell the amount of beam current in a photo, just as it's hard to tell tone in a post (given your odd cagey reaction to my first one), and it's better on a CRT to turn the brightness down for a dim line the moment you realize one of the sweeps ain't working, than to risk it......Hell, when I do a gray scale on a color set with the min brightness setting and the service switch flipped I don't waste any time in turning all the screens down if any are at all bright. CRTs are a scarce finite commodity and should be treated with as much care as possible.
First please dont toss bombs back & forth. This is
just e-mail so we dont know much about motivations without the face to face input. Tom has much to add & you are motivated & informed. Nuf sed. Anyhows the set is a great find. Never seen one, most Philcos this vintage were hot sets & kinda cheap. Even though I am sure you have seen it the dag is peeling off the CRT & when it gets on the chassis will short things out. So a good D&C is in order. Good luck with her. 73 Zeno
By the way what is the purpose of that black paint stuff on the back of the picture tube? Is it supposed to be some sort of x-ray protection, and would it hurt the picture tube to leave it as is right now and run it with that black stuff peeling off as long as it doesn't come completely off? |
That stuff is called aquadag (conductive silver paint), and it's purpose is to filter the HV. The outer coating is grounded (or should be) and the inner coating (inside the CRT glass walls) is connected to the HV....Together with the glass between them they form a capacitor that filters the HV. If that coating is not or poorly grounded many strange symptoms can result, including (in the worst case) CRT implosion (a member reported having a bad arcing ground connection that caused implosion after a few minutes of arcing).
If patches of the grounded side are disconnected from the rest arcing may occur. If the grounded side is disconnected it may float up to HV potential and shock you while servicing the rest of the set. It likes to break into small bits once it de-laminates so it would be a good idea to clean all the bits and any on the tube that are loose...Unless you are fine with the risk of it shorting and burning up one of the more delicate not necessarily easy or cheap to replace coils (IF, h osc, traps, etc.).....
Tom C. Zenith: The quality stays in EVEN after the name falls off! What I want. --> http://www.videokarma.org/showpost.p...62&postcount=4 Last edited by Electronic M; 12-05-2015 at 07:59 PM. |
Thats a very nice explanation of that coating as i was asking about it in my post too.
Nice looking philco! |
D&C is dusting & cleaning. Also refers to a medical
procedure for women. If much dag is missing you can replace it but I dont remember what its called. Be sure to follow the old pattern. 73 Zeno
