What make/model TV set is this?
According to the date, it must've been a CTC12, but not an RCA. The knobs look a bit different, but the secondary controls are in the right spot, plus no UHF. Could be an Emerson, Olympic or a private label set.
go to 2 mins into this video. It's the closest footage I have of the set and may help in identifying it. Note also colors are off in both films due to it being 8mm film. Browns are less vibrant and such, whites are a little off white, reds are rendered as brown. |
Admiral built their own chassis starting the '64 model year, before that they bought Complete RCA chassis. First Communion was a very important occasion for my family as well. It looks like an Italian family, smallish apartment plus lots of great food and plenty of wine. |
For a moment there on the second video I thought "holey moley Doug really does have a time machine and went back to the 60's!"
![]() It definitely is an RCA chassis design. It looks like it uses a small VHF knob with a thin lighted window above it for display of tuned channel, and it looks like they may have fitted the place for the UHF tuner with one of those "UHF ready" badges to cover the hole for the unpopulated knob shaft.
Also, what is a UHF tuner, and what was a UHF ready badge? What did it do? My grandparents' two earlier TVs. First pic circa '54, second late 50s: ![]()
The UHF-ready badge was actually a knockout plug on the front panels of TVs made before '64. This badge covered a hole through which the tuning shaft of an optional UHF tuner protruded. Most TVs which were manufactured prior to April '64 had this badge; at the time, optional conversion kits, containing a UHF tuner and associated components, were available to retrofit these televisions for UHF reception if and when UHF television stations arrived in the area in which the set was to be used. Of course, UHF converters (devices which converted incoming UHF TV signals to VHF channels 5 or 6) could also be used with these sets. Some Zenith TVs of the mid-1960s had provisions for up to six optional UHF tuner strips, to be installed in the VHF tuner's turret in place of unused VHF channels; some sets also had a factory-installed UHF tuner which normally eliminated the need for UHF strips. However, Zenith TVs with Space Command remote control used the UHF strips to provide remote tuning of one to six UHF channels, depending on how many such strips were installed in the tuner. Your grandparents' second TV is a Zenith from the early 1950s. However, I am not sure if the tuner used in these sets could have used optional UHF channel strips, since it may not have been a conventional VHF turret tuner. For this set, an external UHF converter would need to be used to receive UHF channels, if the area in which the set was being used had such channels (not all areas had UHF TV until the 1970s or, in some cases, as late as the '80s). The VHF tuner would be set to channel 5 or 6, depending on which of these channels was not being used by local TV stations, to receive the output of the converter. Because channels 5 and 6 were never assigned in the same city, one or the other of these channels was always vacant in every city in the US, and was the channel to which the VHF tuner would be set for UHF reception. In your area (New York City), for example, you would turn your TV's VHF channel selector to channel 6 to get the output of the UHF converter. The TV's own tuner would operate normally for reception of VHF stations; the UHF converter did not affect the operation of the VHF tuner at all.
Jeff:
Those sets are both Admirals! The first is a 16" round B/W CA 1951, with the famous control cover door that always seemed to be broken off. The second is a 1954 Admiral "Super Cascode" which might of had UHF. Both had Standard Coil tuners, where UHF strips were readily available. |
The two earlier sets pictured are Admiral brand (both B&W). The top one I've seen a few admirals with that control panel, the bottom one the 'pencil box' door seems to have the right number of letters (and enough look to be the right letters) to spell Admiral...Zeniths had a similar layout back then, but so did several other brands. *Given the earlier two sets are both Admiral I think it is likely the color set is Admiral too. Prior to 1963 IIRC Admiral was buying assembled color chassis from RCA to fit in their cabinets (as were most makers offering color before then and a good number after). In 1963 RCA stopped making chassis for other makers but instead opted to license their chassis designs and force the other makers to build it themselves...Admiral and some other makes decided around that time that if they had to build color chassis they might as well engineer their own unique chassis too, and so stopped using any RCA designs after that.
Intact one from tv history site: http://www.tvhistory.tv/1950-Admiral-26X56A-16in.jpg 21 (24?) inch admiral, similar to second set pictured: http://www.tvhistory.tv/1953-Admiral-228DX16.JPG 21 inch table model: http://www.tvhistory.tv/1954-Admiral-T2236Z.JPG jr Last edited by jr_tech; 06-29-2018 at 11:38 AM. Reason: added another pix |
Even when only a few years old TVs of that time weren't anything close to today's "set it and forget it" affair , and the controls had to be regularly tweaked as the set ran to keep things on track . The hidden controls thing may have looked all futuristic and all , but weren't very practical and most folks quickly tired of opening and closing that damned little door every time the picture needed to be made to stop rolling (the #1 drift adjustment) or to adjust brightness & contrast as it seemed each different TV show was filmed in different enough of locations to require setting the picture right when changing channels . Last edited by init4fun; 06-29-2018 at 07:04 PM. Reason: remove unneeded point |
It looks like an RCA CTC12 to me, but the 12 is listed as a 1963 model.
Mid year introduction, perhaps, as the CTC11 is listed as 1961.https://m.youtube.com/watch?v=AYA_A7o5epY Certainly was quite new when the film was made. jr |
Hmm. Any other help?
And.. the date of that video could be wrong. I agree its a CTC12, first one probably introduced in October of 62
"When resistors increase in value, they're worthless" -Dave G |
I am 100% sure of the date. I have my mom's communion record which has the date.
