Aqua-dag paint for CRTs
I need to recoat my 17" Raytheon crt while it is out of the chassis. What are you guys/gals using?
"I know it's true, oh so true, 'cause I saw it on TV"—John Fogerty |
Slip plate. Search for it online. You can get a spray can for under $20.
There are other products too, but I haven't tried them myself.... except for the PB blaster version which had far too high of a resistance to be an acceptable substitute for aquadag.
Is it the graphite lubricant type spray? I see there's some on ebay.
Yup. Just knock off the old loose bits(leave the stuff that is still on there good), mask off where you don't want to coat with paper/plastic and tape, shoot a new coat and your good.
Tom C. Zenith: The quality stays in EVEN after the name falls off! What I want. --> http://www.videokarma.org/showpost.p...62&postcount=4 Last edited by Electronic M; 08-26-2019 at 01:18 PM. |
Aquadag E
I used the original stuff, Aquadag. A search for "Aquadag E" will yield several suppliers. It is available in various forms. I've used the brush on type. It seems to work very well. Slip Plate appears to give others good results. Since coating CRTs is very different than its intended purpose, I've never tried it.
Thanks guys. I'll do some research on the two types and go from there. I'm going to have to take a few pics and do another thread regarding this tube. Will get to that later in the week.
"I know it's true, oh so true, 'cause I saw it on TV"—John Fogerty Last edited by ISawItOnTV; 08-26-2019 at 03:18 PM. |
