LG 42LK450 no video
Turns on, all front controls work, sound works, video inputs seem to work as I've tried two different inputs and sound works. Backlight is on. No video. Is this a t con issue?
Genesis does what Nintendon't |
Can be, or bad screen. If there are two ribbon cables from the screen to the T-con, disconnect them one at a time and see if you get half a picture with only one connected at a time
Disconnected left cable. Got half pic on left side. Disconnected right side, got nothing.
Bad screen. There are threads about people actually isolating which connection on the bad side ribbon cable is causing the problem, but I've never tried to do it.
Here's the link to the manual:
https://elektrotanya.com/lg_42lk450-.../download.html
Both sides of the screen no video? I would look at the TCon board first. Something common to both sides.
Left side works. No right.
There is a "tape" method to isolate the X driver from the bad side (strangely, the display will still run with the other side driving).
There must be youtube videos about adding a small bit of tape under the ribbon cable. The other way is to remove the front mask to expose the side ribbon tabs on the bad side. With a *new* XActo blade, cleanly cut off all the ribbon tabs on the bad side. Careful not to pull the tab while cutting - it's got to be clean. The tape method is safer and reversible, the cut method is 100% but not reversible if the ribbon is pulled on the display. My 70" Sharp is running with one side after I cut off the other side tabs. John |
