I have Horizontal Disease...yet again Admiral 20X1 Chassis
It worked, kinda, bringing it up slowly on original parts. Then I started on recapping the power section and replacing electrolytic caps...turned it on...still worked, maybe a bit better. Kept going replacing caps one by one, checking resistors and replacing any bad ones etc...
Full screen and raster. Cleaned all the controls. Fed in a cross hatch pattern and got junk for the horizontal. Followed the service data for dialing in the horizontal oscillator and frequency...still junk. The oscillator waveform and frequency are perfect...exactly how they look in the service data. ![]() This is the junk I have... ![]() ![]() So frustrated. I see so many restorers on YT get TVs from this era working so well about halfway through testing and replacing parts. The Crosley, Dumont GE Locomotive and now this Admiral all sitting in my shop with mysterious horizontal issues I cannot solve. Mad, frustrated and feeling like I need to take a break from this hobby if I don't get some success soon. ![]() ![]() ![]()
Jesus Ch#@*t. It's my freekin' pattern generator isn't it? Holy crap...lemme check.
I'm a moron.
![]() Never mind. Ancient and unreliable test equipment. Lesson learned. |
Well, sh****t happens... We all sometimes stumble upon that things. In the end, you have great news, a great working TV
![]() Recently I posted about some experiment I'm making with a TV, http://videokarma.org/showthread.php...=1#post3255461 , only to discover after making the title, the culprit is another section ![]() Diagnosing is about that, after all...
So many projects, so little time... |
Similarly on color sets try to have the set facing the same compass direction as you plan to store and use it in when doing scan setup and purity and convergence.
This was a major point with pre-autodegauss sets (e.g., RCA CTC-15 and prior).
I've had advice from some of the experts here several times to make sure the video generator is working properly with a known good TV before making a judgement on what should be addressed. I went down a lot of long and dark streets chasing non-existent problems on several TVs because of forgetting that. The faulty generator is a Sencore 48 I picked up about a year ago. It has performed well until now. I think the issue is the RF output control pot. I have a Leader VG that has always been rock solid so I guess I'll need to break that out for these tests. What I need is the Sencore VG-91. That seems to be the restoration industry standard.
Severe signal overload was first thought upon seeing that first screen shot.
Got it guys. Thank you very much!
