CTC5 Pickup!
My wife went to an estate sale and saw this TV and wasn't going to tell me about it. She was already out in the car when she decided to show me the picture. I thought it was a CTC-7 but its the 21CD789 Whitby! CRT doesn't look necked from the picture. Not sure if its gone to air. Doesn't matter even if the CRT is bad. Its a statement piece and really rare in the Pacific Northwest.
25$ She only had a 20 on her. We got this for 20 bucks... |
Nice set the crt looks like a newer one.
I was hoping for the AXP22. I'll find out tomorrow when I go to pick this up.
Looks really good for its age it may even work
Nice set. I was given one by a fellow collector a few months ago.... problem was the neck and all its hardware were gone, along with the back and knobs, front trim was gouged badly and the finish needed redone. I liked the cabinet enough I initially really wanted to restore it then the reality of winter closing in, not enough space and me having a nicer condition CTC-5 in a cheaper cabinet made me realize my best move was to sell it on to another collector.
Nice find, can’t beat the price. Hope the CRT is good.
Congratulations. I paid $100 for my Whitby in 2013. My CT100 in 2022 cost $100 which seems to reflect a downward trend is old TV prices?
I restored the exact same set 12 years ago. it is in our living room and is used regularly. I call the CTC5 an evolutionary RCA design but can be made to work very well. |
People who collect old TVs do so because they were buying TVs that reminded them of the time when they were kids and the programs they used to watch on them. They're/we're now getting older and our ranks our thinning with new collectors not keeping up with attrition. The same thing happened with reed organs and windup phonographs. Reed organs can be had for the courtesy of dragging them out of the home and I'd guess Victrolas and other makes are probably down 70 percent from their peak some 20 or more years ago. The second reason affects us all - CRTs (particularly early color ones) have a finite life and few of them are available NOS and the ones found as installed have God knows how many hours on them. No one is reproducing them for obvious reasons and there's no suitable way around them. At least with antique radios, a bad power transformer can be bought new or scavenged from another radio, and even IF transformers can be fabricated without too much effort from new parts, and of course the tubes themselves are still plentiful and probably will be mostly forever. John |
A bit of a heavy set! Looks like this set was delivered on Christmas eve of 56! CRT was replaced in 1962. I think it was put out of service after the on off switch shorted out. Burned and the wires crumbled and pulled right out of the switch back. Shorting them out to bypass the switch.
Pulled the horizontal output and damper as I tried reforming the electrolytics. I gave it a good 30 minutes watching the current draw drop. One can was slightly warm. At 85 volts I got sound from my B&K through the tuner to the speaker. Powered it down and installed the damper and output tube. I didn't go above 105 volts and got a green raster. Definitely needs caps all around. So what am I missing... How do I open up the front service panel? Mine seems to be really stuck and I don't want to break it off. Can't check the horizonatal hold or screen controls until its opened!. The set still has all RCA branded tubes, even the two 5u4's, damper and horizontal output. Low hours even after the rebuild? Promising having such a bright green raster at only 105 line volts. |
Tube doesn't look tired
Good question, my crt tester burned out testing a gassy tube. I'm looking now for a new one.
EDIT: I just purchased a sencore CR70. - Matt Davala Last edited by Davala; 02-18-2024 at 07:03 PM. Reason: Found a crt tester |
I tested the 21AXP22A and it tested near new on all 3 guns. Looks like the power switch caught fire not too long after the CRT was replaced.
What do you guys do when you come across previous repairs that don't match schematics? Luckily for me I'm referencing both the sams and RCA CTC5N service manuals and they both match each other. I'm not sure exactly what the tech was thinking with some of these repairs. Here are two of the previous repair botches. Only one of the waxed caps on top was replaced and it should have been a .01 and I found an early orange drop replacement of .0047! C108 on the sams Underneath they really changed the contrast circuit. I tried to draw out what they did and compared it with the sams. Both the sams and RCA service data match. I thought the contrast control might have been replaced with a different value pot but its 500ohms like it should be. I do plan to put the contrast control circuit back the way it should be. Check out that power switch failure and fire! Thats a volume/brightness/on-off combo switch. The brightness and volume still work thank goodness. I have the power switch wires shorted. Any ideas how to replace just the on off switch? I have currently recapped the entire top. Started on the underneath of the chassis this evening. Hopefully I'll have this up and running in the not too distant future! - Matt Davala |
The resistor parallel with the cap looks like a 620 ohm but I measured 82 ohm. Not sure why they reworked the circuit and added a 25 MFD electrolytic on the wiper of the contrast pot to ground. And they grounded the other end of the pot when it should have been left floating.... A mystery.
That cap and resistor shouldn't even be there and that wire should be wrapped or soldered on a lug to pin 1 of the 12BY7. Last edited by Davala; 03-09-2024 at 11:09 PM. Reason: clarity |
Without the service data yet I 'm assuming to access the service controls(screen drive and convergance) I need to remove the trim/CRT safety glass?
Thanks! Last edited by Davala; 02-16-2024 at 09:33 PM. Reason: It sent before I finished writing |
