Old 11-18-2024, 12:11 AM
Aperna1985 Aperna1985 is offline
Looking for Small color Tube Socket Pin out
I'm trying to fix the plugs on my Beltron. I found out which wire is which in the harness coming from the tester. The small 14-pin test plug has a lot of the wires either removed or cut off. If I could find out where the heater is and all the other connections on the pinout I can put it back together. I don't have any tubes handy with the small connector and couldn't look up one to find out what it is.
Old 11-18-2024, 03:19 AM
jhalphen's Avatar
jhalphen jhalphen is offline
Hi to all,
Hi Aperna1985,
This site gives CRT pinouts (B&W and color) by type and brands :
https://crtdatabase.com/tubes
search :
https://crtdatabase.com/search
This 135 page 17,5Mb database gives the pinouts and setups for the Sencore CR-70 "Beam Builder" & CR-7000 CRT testers :
https://forum.retrotechnique.org/upl...PUdOIhECm6.pdf
Another interesting CRT pinout site :
https://web.archive.org/web/20060926...faq.htm#crtpin
Main article :
https://web.archive.org/web/20060926...faq.htm#crtcsa
Hope all this helps you find your 14 pin socket setup,
Best Regards
jhalphen
Paris/France
