Two Way Hourglass Bends on My KCS47
Hi all. Have the 6T65 16GP4 RCA working OK (more troubleshooting advice needed for a different issue than this). The picture is slightly bent pinched in a bow shape top and bottom and side to side. Obviously something to do with the yoke. Any ideas on what might be going on?
Edges appeared straight back in this photo, what has changed? Are you sure the yoke is all the way up to the CRT?
I suspect the sides are straight in the first picture and the curved mask is tricking the eye. For stuff like this a crosshatch test pattern is a good idea as regular programming content and mask shape can obscure the actual nature of what you're looking at.
What's different is the yoke. Let me explain. The cockeyed picture is with my restored chassis from the original dark wood TV transplanted to the blonde cabinet and the yoke on the CRT original to the maple set. After an afternoon monkeying around with its original yoke to straighten out the picture without success, I took it off. The set screw wing nut that allows you to rotate the yoke was cross threaded and you couldn't tighten it down and, the yoke didn't look too good. OK I thought, just take the yoke off the dark cabinet set and put it in the maple set so now. the restored chassis is paired to the yoke it powered in the dark TV. The picture in the original TV didn't have this problem so it probably is a positional issue but I don't know how movement in and out along the neck could cause this.
If the yoke is too far back the beam can be obstructed by the aperture of the electron gun. Also the positioning of the Ion trap can have some influence, since it also bends the electron beam. The trap should be adjusted for maximum brightness with the yoke all the way forward against the CRT bell housing.
Also makes me think of a low voltage issue. Did anything in that part of the circuit change?
Bryan |
That could be too. In general there seems to be an under scan issue. Ordinarily one should be able to fill the mask plus a little more to keep from seeing the edges during line voltage fluctuations. Chris you may want to consider posting your picture over on the ARF forum. Things seem a little slow around here and their are some really sharp engineering types over there as well.
Under the principle of "fix the obvious first," the straight edged picture is with one yoke and the curved edge pic is with a different yoke, right?
I would suggest going back to the first yoke to verify that this change is due to the yoke and nothing else. If that's the case, it may be that the yoke that produces curved sides has either a different winding pattern and or metal/magnetic elements that produce the curve and is intended for a different CRT/receiver, on which it would produce straight edges. Or it may be missing some elements that would correct the curved edges. Can you see any adjustable pieces on either yoke? |
This yoke made a straight edged picture in the original tv in other words, if I had harvested the 16GP4 from the maple set and installed it in my original dark cabinet, as was the plan, it would e the exact same situation. When I got the maple tv with the strong CRT, it had its original yoke and chassis. I took my restored chassis from the original tv and put it in the maple tv but left in the yoke that was in the maple producing the small crooked but straight edged picture. I couldn’t get that yoke to produce a full screen picture so I pulled the yoke from the original tv. This chassis yoke combo produced a dim but straight edged picture in the old set with the weak CRT. I don’t know what could possibly be different other than I didn’t put the yoke in correctly when I did the swap
Correct the socket is on the side of the high voltage cage
If you can't get to the bottom of this, I'd suggest repairing the striped adjustment thumb screw treads on the yoke original to that chassis. Then you'll at least have a known baseline to move forward. Things can easily get wonky when you randomly start changing out parts.
Help me understand - this yoke produced a straight sided image with the same CRT type number or different? With the same focus coil and CRT accessories, or different?
Making a straight raster curve like that is not a minor difference, you should be able to find it. |
