SABA Schauinsland T 2000 color
In another thread I wrote about the Saba Schauinsland T 2000 color, a color tv set of the first color tv generation in 1967. This set has 28 tubes and a horizontal unit which looks like a heating tower. The line transformer is bad. But I got a spare transformer from the electronic recycling depot which belonged to a Kuba color tv set. Today I have replaced the line output transformer and I got the first light on the screen.
The horizontal output unit has two transformers, one for the line deflection and the other one for generating the high voltage for the crt. Did you have color tv sets with two horizontal transformers in the past? |
I think some of the Sony Trinitron sets used this setup...there was a horizontal output transistor for the yoke and a seperate HV horizontal output transistor for the flyback to generate the HV.
I remember at least one Philips set (K8) in Europe that had 2 transformers, 2 PL509 and 2 PY500.
None of the transformers would work if only one failed. A nightmare to fix. |
The two-transformer concept in color television was used by Saba, Grundig, Metz, Graetz, maybe some more. In the Saba, the HV unit gets the input signal from the line output unit. If the line transformer does not work, the HV transformer does not work too. But otherwise the line output transformer could work while the HV transformer does not work. Power consumption of the Saba is 350 watts. And the high voltage output current for the PL509 is 600 to 900 ma. (285 volts). |
I think some of the old CONRAC professional monitors had separate sweep and high voltage supply, but I no longer have a schematic.
Saba
Was this set a top level model in europe in '67? Were there solid state sets in europe in '67?
That SABA is interesting. Would the original picture quality have been competive with the best in '67? |
PHILIPS GOYA (K6): DM 2433,- GRUNDIG T 1000: DM 2398,- TELEFUNKEN Palcolor 708 T: DM 2398,- WEGA 901: DM 2398,- NORDMENDE Spectra-color 7000: DM 2385,- LOEWE-OPTA F 900: DM 2383,- SIEMENS Bildmeister FF91: DM 2380,- SABA Schauinsland T 2000 color: DM 2378,- SCHAUB-LORENZ: DM 2370,- GRAETZ Burggraf: DM 2370,- BLAUPUNKT CTV 2005: DM 2365,- KUBA IMPERIAL: DM 2348,- NECKERMANN Koerting: DM 1990,- Beside them, there were also 49 cm.- color tv sets and the KUBA Porta-color (DM 1798,-) in 1967. The PHILIPS set had 27 tubes too and had a very good video unit with an excellent picture. SABA used so many tubes because many tv servicemen were not familiar with transistors. (This was written in the service manual.) |
I still have a few sets in working order. They came in 49cm(not sure) 63cm 65cm and/or 66 for the latest ones. They were full of tubes and transistors. Philips produced lots of color TV's with tubes when the others already made fully transitorised sets because Philips produced too many tubes in the 70's and needed to get rid of them. |
To Sandy G.: I didn't saw "Outer Limits". Is it a movie or a TV show? |
Did Kuba ever make a color set to compliment the Komet? If I had a Komet, I would be VERY afraid that it would come alive late one night & try to murder me in my sleep...chase me around my house & then skewer me in a corner w/one of those splines...-Sandy G.
Benevolent Despot |
Kuba color tv sets are the worst color tv sets which where produced in Germany. They failed every four weeks, and one had to fix them. Saba color tv set: the horizontal unit is working now, but not with full load. The booster voltage is still lower than recommended. Vertical linearity is and sync don't fit. The crt has very low emission. There is still a lot of to do. |
...sorry I think the idea was that the Kuba Komet looks like a 50's era sci-fi alien.
From Captain Video, 1/4/2007 "It seems that Italian people are very prone to preserve antique stuff." |
Guess I've just seen too many sci-fi/horror flicks on late nite TV..Yeah, I guess you gotta be an American to "get" some of my oddball, snarky humor...But think about it..A Komet, w/an evil grin on it's screen, chasin' a guy around, every once in a while, jabbin him in the butt w/the long spike, the guy hollerin', "YEEE-OWWW",grabbin' his poor, sore butt, the Komet goin' "Heh-heh-heh !" as it runs after him again...They didn't have Hanna-Barbera cartoons on TV in Germany back when you were a kid, did they? Huckleberry-Hound, Quick-Draw McGraw, Snagglepuss, Yogi 'n' Boo-Boo,Augie Doggie & Doggie Daddy...If you'd ever seen many of those, you'd understand...I think...-<grin>-Sandy G.
Benevolent Despot |
Conrac used a stand alone HV power supply. I still have some in everyday service. They are Delta gun too. I'm going to make sure they don't hit the dumpster when they get replaced with HD monitors someday.
