Old 09-21-2007, 09:48 PM
grimer's Avatar
grimer grimer is offline
Will a 21fjp22 work in place of a 21cyp4
Old 09-21-2007, 10:01 PM
Old 09-21-2007, 10:46 PM
reeferman's Avatar
doubtfull you'll get a good gray scale without changing some resistors to compensate for more efficient phosphors. Service bulletins were published, I'll see if I can find one. I sure can't trust my memory on this one. If needed, you can try swapping drives../red & green for magenta, red & blue for yellow, etc.
Old 09-23-2007, 07:44 AM
stromberg6's Avatar
Don't forget to be careful about new the anode connector you will install. Wrap layers of tape around the ring near the cavity on the tube to prevent arcing through the HV connector to the ring.
Any other suggestions on this?
Kevin
stromberg6
Old 09-23-2007, 11:38 AM
John Folsom's Avatar
CRTs
Comparing the "Examples of use of Design Ranges" on the datasheets for the 21CY and 21FB, they will sub for each other.
John Folsom
Old 09-30-2007, 03:14 PM
This is a 100% retrofit and will work perfectly. The gun mounts are the same gun on both tubes and from the 21CY you don't use the 56K resistor with spring that bridges the two anode buttons. I don't know about changing any resistors as you will get better tracking with the 21FB/FJ and will make wonderful color. I did this many, many times in the '60-70's and never any problems. Don't worry about any resistors as nothing has to be changed except leaving off the double button anode resistor for the newer tube. Julian
julian
Old 10-05-2007, 01:56 PM
holmesuser01's Avatar
Originally Posted by julianburke View Post
This is a 100% retrofit and will work perfectly. You don't use the 56K resistor with spring and you will like it. I did this many, many times in the '60-70's. Don't worry about any resistors as nothing has to be changed. Julian
I second this comment. I ran my CTC-10C with an FJP22 tube for years with no issues. I finally found a CYP22 to rebuild, and this tube has been in this set since about 1984. Thank you, Video Display Corp. of Atlanta. I wonder if VDC is still in business?
Old 10-05-2007, 01:58 PM
VDC is still in business, but not taking round color CRTs.
John Folsom
Old 10-05-2007, 02:22 PM
Findm-Keepm's Avatar
Followin' the Rules...
Is Empire Video still in business? Several websites have their rebuilt tubes - maybe they'll still rebuild a 21" round tube - they did in the late 80s.
HBF Electronics (No affiliation, just came up on a search) carries Empire tubes - mostly 19/23/25/25V stuff.
Possible resource...
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
