Old 01-12-2013, 05:05 PM
Geist Geist is offline
450 Volt Caps
Hi All;
I am looking for caps at 450 volts, I looked at Mouser, which has been suggested.. When I looked for 10 mfd, the lower priced ones were in the range of $1.00 to $3.00, Which is fine with me..
So, I go looking for 20 mfd and 40 mfd and 80 mfd, Suddenly the price jumps from about $20.00 to about $50.00 in round numbers.. Am I selecting the wrong things, or do the prices jump that much after 10mfd ??
At Just Radios, for 20mfd thru 80 mfd its between $1.00 and $4.00.. Am I missing something ??
THANK YOU Marty
Old 01-12-2013, 05:19 PM
nasadowsk's Avatar
Damn does run fast…
You're doing it wrong. Granted, i'm seeing some sizes are a bit pricey, but most of what i quickly searched was under $10 a cap.
Try also Digi Key...
Old 01-12-2013, 05:24 PM
David Roper's Avatar
console lover
I only consider buying from Mouser when the cap is an unusual value not available from the usual sources. Ordering from Just Radios is indeed very straightforward and their pricing is reasonable, why not just go with them?
tvontheporch.com
Old 01-12-2013, 05:41 PM
Hi All;
So, what am I doing wrong ??
On digikey, it shows nothing for me..
And I would just be as glad to stick with one source..
The only problem with Just Radios is the time lead for shipping..
THANK YOU Marty
Old 01-12-2013, 05:42 PM
You know that you can use a 22mfd in place of 20mfd, right? If you search Mouser for "modern" values like 22, 33, 47, etc., you'll see that they are much cheaper than "old timey" values like 20.
Phil Nelson
Old 01-12-2013, 05:49 PM
Hi All;
Thank You Phil, No, I didn't know that.. I just put in the values specified on the Cap that I am replacing..
THANK YOU Marty
Old 01-12-2013, 05:57 PM
Hi All;
Yea, that's more like the prices, I was looking for.. $1.00 to $3.00 A lot better than $44.00, that just was a bit pricey for me..
THANK YOU Marty
Old 01-12-2013, 06:55 PM
This article about recapping has basic info about choosing replacement caps:
http://antiqueradio.org/recap.htm
An outfit like Mouser can sell (and thus orders) vast quantities of caps in the modern values, so they'll naturally be cheaper than little-used values.
Phil Nelson
Old 01-13-2013, 03:53 PM
toolguy toolguy is offline
You try here? Click on the order form and you'll see their 450v caps.
http://www.justradios.com/capacitors.html
Old 01-13-2013, 05:41 PM
Hi All;
Toolguy, I already knew of where to find and order from Just Radios, it was their delivery time that I didn't like.. But, others may need the link.. Even if it is for comparison.. So, Thanks..
THANK YOU Marty
Old 01-15-2013, 10:58 PM
M3-SRT8's Avatar
M3-SRT8 M3-SRT8 is offline
I use Just Radios for Tubular Caps. They have the "Prewar" Cap values, i.e., .05 rather than .047, etc. Their prices are good.
I use Mouser for Electrolytics. They are fast shippers, good pricing, wide selection. They have radials as well as axial leads, and 105 C rated and long-life caps.
Buy your stocking order of Tubulars from Just Radios, and your project specific Electrolytics from Mouser.
Old 01-15-2013, 11:42 PM
Einar72's Avatar
Einar72 Einar72 is offline
Chasin roundies since '79
Just shop carefully on eBay and you can avoid imported junk...
Old 01-17-2013, 11:23 PM
robert1's Avatar
robert1 robert1 is offline
Those "high dollar" caps that Mouser sells are Genuine Cornell-Dublier capacitors. they are expensive but, they are made just like the ones that they made in the sixties & Seventies. when i restore a nice piece of equipment, i usually order these.
