'55 Philco
I recently acquired a 1955 Philco 21" with a swivel base, model 4113. The set is in very good condition except for a missing faceplate/cover that attaches to the middle of the set where the adjustment knobs are located. I believe it has the Philco name on the cover. If anyone can locate one of these, please send me a pm. This is the only part missing on this otherwise great looking set.
Larry Last edited by VA561; 03-12-2013 at 05:06 PM. |
Those were great sets.
I had a bad vertical output transformer in one, recapped it then sold it because it worked so well. The control cover is not much more than a trim piece that allowed top and bottom finger access to the knob IIRC. |
Starting with the 1957 model year, it was down hill, for the company after that.
Maybe this is why Zenith held off on the skinny-set craze! This also signaled Philco's descent to GE's level of quality in the late 50's. |
I have a similar green Philco table model that had the trimpiece on it; but, I accidently broke it while moving it. From what I'm finding out, those trimpieces were very easily damaged.
http://www.youtube.com/user/radiotvphononut |
I knew it wasn't going to be easy finding a replacement cover/trim piece for this set. That being said, I have found parts for other tvs on this forum that I thought would have been next to impossible to find. I hope someone out there has one as a spare or even a broken one that can be repaired. This set has a replacement picture tube, a TUNG-SOL. 21ZP4B. It has a great picture.
Can someone tell me what the small plastic window is just to the left of the channel knob? It has a pointer built in the metal plate on top of the window
That window is for the UHF, if yours was equipped with it. I want to say that, on one I had, the indicator was there whether you had the converter installed or not. I've had a few similiar models, and managed to break the cover on two of them. I still have one trim piece with a little chunk missing. There were different versions, with some set up for a wider knob than others. I also have a NOS cover that I think is for a slightly newer version.
Bryan |
A better picture.
