Old 03-15-2013, 10:26 PM
cbenham's Avatar
cbenham cbenham is offline
Conrac TV Tuner missing CH4 'strips' from the Mid 50s
I have a Conrac Model 650 TV Tuner that uses a Standard Coil tuner. It is working pretty well but is missing the original two tan turret strips for Channel 4.
The attached photo shows two strips in the CH 4 position labeled "4F".
These are strips borrowed from an Admiral 17 inch set. I also tried the two strips from an Admiral 19T 7 inch electrostatic set which are labeled "4".
While these two sets of borrowed strips work, sort of, they are much different than the "3Q" and other "#Q" strips that are original to the tuner.
The Q type strips seem to have much broader bandwidth and output a much more proportionally correct NTSC color signal to display on a scope.
The two sets of borrowed CH4 strips seem to have a much narrower bandpass and produce about 50% more sync, as if they were
specifically designed for early B&W sets used in remote areas.
Does anyone have a "KEY" to the various specific types of strips by Standard
Coil such as the Q, plain and F types?
Does anyone have a standard coil tuner with Q series VHF strips, or maybe just the two "4Q" strips they would like to sell?
Thanks for any help with this.
Cliff
File Type: jpg Conrac 650 TV Tuner with Standard RF Tuner .jpg (47.9 KB, 29 views)
Old 03-16-2013, 08:58 AM
IIRC, the Q strips were used in the tuner, when the RF amp was a 6BQ7.
The "Q" tuner was also designed to be used with UHF strips.
Old 03-16-2013, 03:27 PM
cbenham's Avatar
Thanks very much for this information. I did not know about this.
The tuner does have a 6BQ7 for the RF amp and a 6J6 local oscillator and mixer.
It also does have 3 UHF strips installed.
Cliff
