Old 12-11-2013, 12:03 AM
searstvman searstvman is offline
Exclamation sears sr 3000 crt tv oct 1987
tv did it again channel box went off no big pop this time tho just no low power again which is the 120 am fuse i think the connector is faulty cause i moved it around and got it to work and thats where the problem was when i was using the ohm meter so anyone know what those clips are called that hold the fuse i wana replace it for good so i can get the tv working again
Old 12-11-2013, 07:05 AM
WISCOJIM WISCOJIM is offline
Please continue your posting of this topic in the thread you started first, rather than starting a new thread for each post.
Old 12-11-2013, 01:02 PM
I assume you mean the 2 clips that hold the fuse.
Just take them out & replace with a pigtailed fuse.
Also be sure its not a bad connection under it.
