Old 11-14-2014, 06:33 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Late-model filter can contents
This was tied to a CTC110B chassis from 1982. I thought it unusual to see an old-style filter can on such a recent chassis. It was a single-section can though.
I want to rebuild the cans in my Admiral so I thought I would get some practice by taking this one apart. I used heat to remove the guts as described in the sticky above. The tar holding everything in was almost entirely at the top. I was surprised to find cutouts for three other terminals in the rubber and plastic spacers. I didn't have to snip the plate lead as it was detachable.
I'm going to see if I can find a way to rebuild these so that they can be maintained easily but look as close to original as possible. Hopefully I won't completely destroy this one while experimenting, but if I do, no big loss.
I decided to take a picture due to the differences between this can and the one in the tutorial. Interesting if nothing else. I didn't melt the rubber spacer, I damaged it with the pliers. Also, I eventually learned how to pry up the bottom edge of the can without damage. I found prying and lifting at the same time turned the trick.
Old 11-15-2014, 05:25 PM
I wouldnt worry to much about making it maintainable, with
modern caps it will probably outlive us all. For choosing caps
I would ask findem-keepem sp? he has the best grasp of
caps here. Keeping it looking good is the real challenge, way beyond
my abilities............
Old 11-16-2014, 03:20 PM
zenith2134's Avatar
I was surprised the first time I saw those metal cans labeled 'condenser' on my '83 CTC-117.. All the RCA color tabletops of that era used em. Personally, I aim to keep my old TVs in top operating condition, with less of a concern paid to cosmetics of the chassis.
Old 11-16-2014, 05:25 PM
Jon A.'s Avatar
I think I would go no further with part rebuilding than the multi-section cans. I'm not going to bend over backwards to make every little bit look 100% original.
Old 11-16-2014, 08:00 PM
And they went left & right.Gave a nice hour glass pix. The OEM's
were expensive, I think abt $20 net IIRC. Odd value to boot.
Some had a second section IIRC a 10 mfd for the 200V supply.
Old 11-16-2014, 08:07 PM
Jon A.'s Avatar
Mine is 820 mfd. Well, it was anyway.
