#61
Well, finally wrapping this thread up with a success! Here's the Admiral playing away in Nick's room, on a dolly to make it easier to wheel over towards the bed
![]() The loss in vertical sweep was, of all things, an intermittent shorted connection from his recap job. Had to have my friend Ed sort it out because I couldn't find it! For his first television restoration though? Not bad at all! Once that one crossed wire was sorted out, everything else Nick did was perfect ![]() Last remaining job is to apply the new decals!
"Restoring a tube TV is like going to war. A color one is like a land war in Asia." |
#62
Looks great, though I'd use a wider wheelbase dolly. Less tippy.
Nice to see that TV making a picture, after all the work you and your son put into it.
I don't see a converter or cable box anywhere, just a pair of rabbit ears on top of the cabinet. Unless the antenna is just for show and you are feeding the set with a VCR or DVD player, it would be impossible to get any kind of reception unless Buffalo still has one or two analog TV stations. Even Canada's television system has gone (mostly) all digital, so you would be hard-pressed to find any analog TV there either. The only other thing I can think of is you have your own in-house TV system, using agile modulators. I remember reading somewhere in this forum that you do have such a system.
Jeff, WB8NHV Collecting, restoring and enjoying vintage Zenith radios since 2002 Zenith. Gone, but not forgotten. Last edited by Jeffhs; 06-17-2015 at 06:33 PM. |
#64
Good idea. I have another that I can use for this. Gonna go change it over right now
![]() The only reason it's on this one is that's what we used to wheel it around in the basement on.
#65
![]() I just set it to whatever I want to watch (or whatever he wants to watch), and tune the TVs in to channel 9. What's doubly nice about it is that I can transmit test patterns, crosshatch, indian head, etc....eliminating the need to hook up a TV analyst or dot bar generator. Just rabbit ears and dial it in!
#66
#67
You son does quality work and he now owns a TV way cooler than anyone he knows. Have you picked out a radio for him to work on next? He can add a bluetooth receiver for twenty bucks. I'd suggest something like the Zenith 845, but I'm sure you can find something nice, maybe with an extension speaker for stereo.
Instead of using a dolly to move it around, though, why not mount wheels on the legs? You can buy small wheels with a mounting plate at any big box hardware store (or online) and it's only four small screw holes. Not like drilling a big hole in the leg for for a caster shank. I used a larger set of these wheels for my heavy oak work table (used to be a dining room table) and let me tell you, it moves around on carpet with ease and is only a few inches taller which isn't a problem. |
#68
I think the dolly's just for the moment. We still have to pull the set apart again to get the decals applied....
