Old 11-17-2015, 06:04 PM
azbigsam azbigsam is offline
Looking for some capacitors
I'm looking for the following capacitors:
.001uF and .0047uF, both rated at 10,000 volts.
Does anyone know of a good online source for these at a decent price?
Thanks
Old 11-17-2015, 06:11 PM
Gregb Gregb is offline
Just Radios should be able to supply those.
Gregb
Old 11-17-2015, 08:54 PM
Findm-Keepm's Avatar
Followin' the Rules...
.Allied Electronics carries the ASC brand in 10Kv - they have the .0047uf, but are out of stock on the .001 (1000pf) in 10Kv. X675 is the ASC type.
Brian
USN RET 22YRS (Avionics/Cal)
Old 11-20-2015, 09:56 PM
I ended up ordering some of these:
http://www.ebay.com/itm/251896076968...%3AMEBIDX%3AIT
Hopefully they work out.
Old 11-20-2015, 10:18 PM
WISCOJIM WISCOJIM is offline
I hope they'll work for you, but I myself would never stick capacitors that look that old into a repair when modern ones of those values can likely be found. Do you have any idea how to read the date code? I'm guessing they are from the third week of 1988, already 27 years old.
Are those for a Pilot TV by chance? If so, there are a lot of threads on here and ARF that should reveal where they found their high-voltage caps.
Old 11-21-2015, 10:30 AM
I scrapped a Knight-kit scope that had two .1 caps @ 2KV. They appear to be the ASC brand. They checked out perfectly, no leakage whatsoever.
I'm going to install them in my two Porta-Colors, without regrets.
