Old 07-28-2022, 02:55 PM
70smidfiguy's Avatar
70smidfiguy 70smidfiguy is offline
JVC HR-D470U detects and plays EP only
Hello all,
I have two HR-D470U's one as a spare for parts.
The best one of the two, when you insert a pre-recorded movie, the deck switches to EP and plays (of course) slow.
I'm only interested in recording HIFI audio with this unit.
I have swapped the capstan motors with the same result on both but I suspect this is an electronic detection issue.
Hoping maybe someone had run in to this problem and solved it.
Many thanks in advance.
Old 07-28-2022, 08:32 PM
Blast's Avatar
Blast Blast is offline
blast, blast...
What happens when it makes its own recordings at both SP and EP? Will it playback those correctly?
Old 07-30-2022, 12:00 PM
It still switches to EP. Ill try an EP recording and see what happens there.
Old 07-30-2022, 01:34 PM
djfivos djfivos is offline
I'm suspecting something is wrong with the control track circuit. Typically most VHS machines default to SLP/EP on playback unless they detect SP or LP control track pulses. Do the recordings made on this machine play fine on other machines?
Fivos
Old 07-30-2022, 08:23 PM
Blast's Avatar
blast, blast...
Fivos
Yes, that's the next question.
Old 08-04-2022, 06:51 PM
WCV82 WCV82 is offline
I had the same problem but just in reverse on a similar JVC model, it would only play SP tapes, either commercially recorded or home recorded, and could not track LP or EP tapes. After 2 deep cleanings it then played all tapes fine. A few months later I did notice that it did have problems tracking tapes that went back and forth between SP and EP (home recording) to the point where it went from fast speed to slow. However, that only occurred on a few tapes from the same batch so I'm thinking it was because of the original recording VCR.
Old 08-16-2022, 05:07 AM
redk9258 redk9258 is offline
I recently repaired my HR-D470U. It was a couple of hi ESR caps in the control circuit. I think I made a post here about it.
Old 08-16-2022, 05:08 AM
http://videokarma.org/showthread.php...26#post3232126
Hope that helps!
Old 04-15-2025, 08:31 PM
I've found another thing that causes this exact fault. In the power supply there is a 3300uF cap that goes bad. It causes a lot of ripple on the 5V supply. I have replaced several of these, both Elna and Matsushita, restoring operation to normal.
