Old 02-02-2024, 01:55 PM
It seems that there are substantial differences between the two that would need to be addressed before it would work well it looks like.
https://tubedata.wernull.com/sheets/168/3/3KP1.pdf
http://www.r-type.org/pdfs/d5-100gh.pdf
Namely in the deflecting plates capacitive loads.
3KP1 seem to be around 8-11 pf, and d5-100 is much lower, .09-3pf? Hard to tell, not in English.
Also the deflecting plates voltages a a bit different, this is no doubt the source of the problem.
Does this the small crt needs more deflection voltage
Old 02-02-2024, 02:03 PM
Hard to tell, one is listed in volts per inch, the other is per cm, not sure how that crosses over.
But more likely than not, it's the difference in pf that is the issue.
Old 02-02-2024, 02:05 PM
And the pf cannot be made up with the proper cap ?
Old 02-02-2024, 02:14 PM
That will have to be looked into by someone who knows the circuit a bit more, but I'm sure it can be adjusted.
Old 02-02-2024, 02:15 PM
Is The pf difference with the circuit or the deflection plates themselves
Old 02-02-2024, 02:18 PM
I did manage to get the screen full but the people on the screen part was missing to big stretched
Old 02-02-2024, 02:30 PM
Yes, since the distance from the center of deflection to the screen is so small in this tiny tube, deflection sensitivity is poor.
Old 02-02-2024, 02:31 PM
The original set and circuit must have been made with the 3KP4 in mind, and the capacitive load it would put on the circuit, so it makes sense that a different tube would have unexpected results, so as mentioned, someone with a good understanding of this set may be able to help adapt it.
May only need a few changes.
Old 02-02-2024, 02:36 PM
I wonder if the hv deflection caps would make any difference
Old 02-02-2024, 05:37 PM
Maybe a different vertical size pot instead of 5 meg
Old 02-02-2024, 07:22 PM
Unfortunately, it won't be as easy as a single part, It will take someone with knowledge of tube circuits who can look over the documentation for the set and theory of operation and make suggestions on how to adapt it better to that CRT, it may just be needing a few changes of caps and resistors in the vertical drive / output area to make it a better match.
Old 02-02-2024, 10:08 PM
Perhaps it would be useful if the B+/B- voltages applied to the vertical circuit were increased ....what do they measure now?
Old 02-03-2024, 06:06 AM
So I have to figure out the b+ voltage to the vertical amp or multi.I’m not certain where the voltage comes from for vertical possibly a tap from focus voltage
Old 02-03-2024, 02:55 PM
B+ is from the 25Z6, and B- is from the 35W4...Don’t you have a schematic?
What do they measure now?
Old 02-03-2024, 03:17 PM
Yes I know where to get the b+ but I thought you meant the b+ to the vertical circuit I’ll check the voltage at the rec tubes I do know it’s close to what it should be. And yes I have a schematic. How would I be able to up the b+ ?
