Old 06-19-2025, 01:12 PM
Something else to consider is try to order more than you need to get the price break. If you need 3, 4.7K resistors - get 10.
Pretty quickly you'll see which values you most often use by what you have left over.
Old 06-23-2025, 02:01 AM
TV-collector's Avatar
TV-collector TV-collector is offline
Hi all,
The "inductive spiral" construction is only inside a satellite tuner a problem.
I have read, that only, when you are dealing with frequencies in the GHz-area (Giga-Hertz), the "spiral" will work as a damper.
Regards,
TV-collector
Scotty, beam me up, there is no more 4/3 Television and AM radio in Germany!
