Old 04-01-2026, 12:48 PM
Correct. If you have seen any of Bandersen's videos on U-tube about ES sets, or any in general, he often uses a test CRT for the bring up and debug stage, and then changes to the tube that was with the set in the final stages.
A 7JP4 is far too rare and hard to get to risk in an unknown chassis, but a 3BP1 is easy and cheap to get.
Old 04-01-2026, 04:22 PM
Oh ok I wasn’t sure the base was the same
Old 04-02-2026, 01:08 PM
Yes, the 3BP and 3JP CRT families will sub.
Here's the video where I demonstrate them.
https://youtu.be/4InEz1btbvM
Old 04-02-2026, 09:47 PM
Damn...
The Caps from Just Radios are not cheap!
4X .005 @6k
2x .0005 @6k
Old 04-03-2026, 06:23 AM
Damn...
4X .005 @6k
2x .0005 @6k
Do you mean 4x @ 6 bucks each ?
Old 04-03-2026, 06:56 AM
No they are HV parts 6 KV, $7 each $41.94 tot
Old 04-03-2026, 09:11 AM
Both DigiKey and Mouser have the much less expensive Wima 6,000 volt caps.
Use 6800pF in place of the 0.005 if they are out of the 4700pF
https://www.digikey.com/short/b9nchjq0
Old 04-03-2026, 09:28 AM
7 bucks each wow it’s gotten expensive along with everything else in this country
Old 04-03-2026, 11:55 AM
As bandersen showed in his video, those caps can be used, but are harder to put in due to their shape and size, the cylinder kind look like the OEM, and are less of a pain to use.
Old 04-03-2026, 01:09 PM
I never used those red square caps always used the white cylinder looking ones.
Old 04-03-2026, 01:41 PM
Besides my first moto VT-71 (white tubulars in that one) I always use the red rectangular WIMA brand caps, and even keep a handful in-stock. The red Wimas work fine in every electrostatic make and model I've worked on... Having to add lead on isn't a big enough deal to justify the more expensive parts in my book... Heck, I have to add lead length to some 630V caps these days.
Old 04-03-2026, 03:17 PM
Well for my first one, I wanted to be like totally tubular, for sure ya know!
That being said, it does seem that JR is inflating their prices a wee bit!
Old 04-03-2026, 03:23 PM
They're the only game in town for new axial HV caps as far as I know. Otherwise, you need to order directly from a parts distributor. We're lucky anyone sells them in small quantities.
Surplus Sales of Nebraska has some old axial Sprague caps that could also be used. The value is a bit larger at 0.015uF and they're a few decades old but should work.
$4.25 each if you get 10
https://www.surplussales.com/items/1...age-capacitor/
Old 04-03-2026, 11:25 PM
A pic of the chassis. not done anything to it yet.
http://suzaku.live-evil.org/20260403_230850.jpg
You can see, someone has been at it before...
Old 04-04-2026, 12:55 PM
Looks similar to the vt71 series Motorola
