Old 11-14-2008, 09:42 PM
Ampico-kid's Avatar
Ampico-kid Ampico-kid is offline
Originally Posted by Blast View Post
Oh, come on! How'd you Photoshop those old pictures on the front of that set?
Oh DARN !!!!! Somebody's finally figured out my secret !!
Old 11-14-2008, 10:44 PM
vintagecollect's Avatar
1977 Zenith Chromacolor II
A Very Modern Zenith
Old 11-15-2008, 12:45 PM
Dan Starnes's Avatar
Gizmo Nut
I am very impressed.
Dan
Old 11-18-2008, 01:55 PM
I'm guessing that someone must make a special driver that will work better than just a small screwdriver on those shafts-the driver keeps falling off while trying to adjust things.
Bryan-
I have a set of TV tweaking tools that includes one or two with a flat blade flush with, or slightly recessed inside, a hollow shaft. They work quite well on those adjustable coils and small-size slotted pot shafts. You should be able to find some from GC (if they are still around) or another supplier.
Old 11-18-2008, 01:59 PM
Here is a link to a few pictures of my CTC-5 Super with the same chassis. I still need to find and fix a problem in the color circuits that causes the ghost-like video.
http://216.101.184.5/ctc5/
Old 11-18-2008, 02:13 PM
Thanks, Chris, I'll do some searching. I have a pretty good collection of old diddle sticks but not one of those.
Old 11-18-2008, 07:10 PM
Usually color TV sets use a delay line on the luma signal, to compensate for the delay of teh chroma demod circuits. If that delay line doesn't have a proper termination resistance load, it could cause an echo (ghost).
Old 11-18-2008, 08:27 PM
Yes, looks like a delay line problem - check the delay line ground as well as resistor values in the video amp circuits.
Old 11-19-2008, 01:42 AM
Steve D.'s Avatar
Steve D. Steve D. is offline
Bob,
Outstanding restoration. My very first color set was the same RCA "Aldrich" Special model. I bought it used in 1962 and it produced a great picture. Like that rare optional base as well.
-Steve D.
Old 11-20-2008, 01:16 PM
Thank you for the tips. I will check the delay line and associated circuitry when I get back into the set. I will be happy if I can get it looking nearly as good as Bob's picture.
Old 11-25-2008, 01:51 AM
frenchy frenchy is offline
Frenchy
Yowza that picture looks fantastic, congrats on the restoration Bob. I think I'll go to bed now and watch something on my CTC-5 in my bedroom before I go to sleep : )
The contrast/brightness mod is on my to-do list.
Frenchy
