The amp, pictured was built in November, 1963. It's stamped 11M63 on the back. Probably the last of the larger tube amps from Motorola. Everything newer seemed to be solid state.
Several years ago, I had one lower end Motorola AM/FM/phono tube console that might have been a little newer than this one; but, IIRC, everything was on a single chassis and it was a standard two channel set-up. I junked it because the cabinet was rather beat up and the tuner had bad IF transformers for both AM and FM.
http://www.youtube.com/user/radiotvphononut |
This thread has inspired me to get started on the '61 model Motorola console I have out in the shop. It has a Danish Modern cabinet by Drexel and the big amp with 6 6v6's. I need to recap it as all I get is very low volume and the typical 60 cycle hum which usually indicates bad filter caps.
Dumont-First with the finest in television. |
The more circuit schematics I look at on sets of this vintage, Id say Motorola was right up there with Zenith and RCA, as far as High fidelity is concerned.
It would be fun to get some reviews at the time (not necessarily consumer reports) on sets of this vintage
"When resistors increase in value, they're worthless" -Dave G |
These were well built, had quality speaker drivers and amplifiers inside, good changers, and were better than average consoles. And they had nice cabinetry (often Drexel made). Yes, among the better consoles.
