Old 06-03-2018, 09:35 AM
mbates14 mbates14 is offline
VT-71 Ballast 17A485459 in a TS-4D?
I picked up one of these ballast tubes years ago when there were plenty on ebay. I am sure this topic has probably already been beat to death. Here and elsewhere, but.
I stuck it in my 4D but it obviously didnt work after some research as they made 2 different tubes and I was unaware at the time.
So, Is there a modification that can be done to allow the 17A485459 Ballast to work on the TS-4D? Just curious.
Old 06-03-2018, 09:52 AM
Doing some more searching, I found this:
http://antiqueradios.com/forums/view...80269#p2680269
Basically states that they removed resistor E, and moved the common tie point from pin 5 to pin 6.
So technically I could swap the wires from 5, and 6, but then I lose the 22 Ohm resistor.
But according to the TS-4D schematic, that resistor is in parallel with the audio preamp tube filament.
Question is, Why? and what would happen if it was "missing"?
Old 06-03-2018, 10:25 AM
The 1st audio tube is at the end of the heater string in the 600ma leg.
The 6SQ7 is a 300ma tube so the resistor has to be in parallel with the heater to equal 600ma. 22 ohm and at least 2 watt.
Old 06-03-2018, 06:34 PM
Thanks for the explanation, clears that up!
Old 06-29-2018, 08:08 PM
edison64's Avatar
edison64 edison64 is offline
THE A-1 WIRELESS MAN
Location: NW INDIANA THE MAPLE CITY LA PORTE (GO SLICERS)
Just a question about the ballast does anyone have a list of the ballasts used on the specific chassis I swear I had one somewhere but I just can't find it now would be handy to have
RCA VICTOR and its dealers bring you......
Old 06-29-2018, 11:52 PM
only the ts-4j late uses the 17A485459. All the others use the 17A470303
