I'm hoping that the crt will get better. I had the bias switch set in mid position for the pictures. Ed |
Been there, done that. |
EdKozk2,
How much did you pay? I'm just wondering what the market is today for buying a used CTC-16. |
http://www.videokarma.org/showthread.php?t=268446 Last edited by EdKozk2; 02-15-2017 at 12:09 AM. |
The listing is still there..
Looking for an all tube or hybrid color TV set from the late 1960s, early 1970s that's in a steal cabinet.. |
Tv collector,
Your right, the first time I tried the link , ebay sent me to a bunch of ads. The top of the ad page said, " 0 results ". I tried the link latter and it worked correctly. |
I finally got back to this set this week. Degaussing the crt made a world of difference. All three colors are purer.
I wanted to check the horizontal output cathode current. Is there a jumper link to disconnect the cathode from ground ? I'm hoping for an easy way to get a current reading . Ed Last edited by EdKozk2; 11-30-2018 at 01:27 AM. Reason: brighter pictures |
Unless someone added a cathode fuse above chassis (something I recommend) the only easy way to do it is a test socket with a provision to insert a meter in series with the cathode or measuring the plate current (which Involves dangerous voltages).
Took your suggestion, should arrive middle of next week. I didn't even know these were produced. Ed |
CTC 16 H Ideal tv set for a NYC apartment. this one, is my Frankenstein set. (Zenith picture tube) model gf629w name the Bromley. Long hours set with a new flyback. Reliable and dependable. your new set will deliver the goods.
