RCA Victor portable TV from the 1950s
Hello everyone today I finally got the old TV I was talking about, it's a 1950s vintage RCA Victor 12" B & W portable TV that is in a metal and plastic cabinet with a handle on top and it's white colored.
Interesting thing is that it's got both VHF and UHF tuners on it and built in antennas. Any information about the TV? Pictures of the unit in question posted below. |
Also was this considered a high end set? |
check filament of all the tubes.
This isn't a series string set, it has a power transformer in it, and I don't see any fuses in it.
The tube placement chart and chassis number is missing from the set so I don't know if I can find a service manual for this TV or not. |
Here's some pictures of the inside of the TV.
Very nice! Looks like it'll clean up real well, should be a fun project. Sams index says 513-2.
I have the same set, 1959 I think, great performer when restored.
It has a fusible resistor I think, that will kill it if it's open. |
But there was one part near it that I wasn't sure about what it was or what it was supposed to be and it appears to be damaged whatever the part is, and it looks to be part of the power supply. see picture below. |
Unfortunately I don't have Sam's Folders going that high, my Sam's Folders only go up to 469 and they aren't even a complete set of Sam's Folders going that high.
That looks like a Thermistor, I seem to recall replacing one in my set. If it is you could just jumper it and power it up with a variac or dim bulb tester.
Just found it, 1.7MB in PDF format, can you provide email address, I send it to you ASAP. see if you can use it.
If so what was the purpose of that thermistor in that spot, and how do I jump it? |
You could literally use alligator clips on either side or solder a wire to bypass it for the time being. I'd recommend replacing it if it's bad, though. Feel free to correct me if I'm wrong. I'm not nearly as experienced as some people here.
To keep your tubes running smoothly, make sure to dust underneath the glass as well. |
