Old 09-15-2020, 04:11 PM
help me ID this mystery GE roundy plz!
https://imgur.com/WvpxRTp
i know these px suck but I found this locally and I'm tempted to get it, but can find NOTHING about it, even with the MO# info from the back
https://imgur.com/HovvPWO
https://imgur.com/k54TvR3
https://imgur.com/wXwRzpB
what is it, who REALLY made it?
Philco? RCA?
if I cant find service info on it, it's just parts, I'd rater restore it.
any help welcome!
thanks!
Old 09-15-2020, 05:51 PM
SAMS lists a GE M939ACD:
https://www.samswebsite.com/en/photo...earch&s=Search
Old 09-15-2020, 06:00 PM
SpaceAge's Avatar
SpaceAge SpaceAge is offline
The back cover and front control layout resemble this GE in a Shango066 video, which he identified as a CTC-15 clone.
https://m.youtube.com/watch?v=kTesct_7uOA
Old 09-15-2020, 06:56 PM
thanks! I guess I was looking up the MO# in sections, not as a whole :/
that's why I got nothing
Old 09-15-2020, 09:49 PM
reeferman's Avatar
I have the Photofact in PDF if needed.
Old 09-16-2020, 09:32 AM
If you miss it, you're not missing much.
That thing's a dog. I scrapped one. The only good thing about it was the RCA 21FBP22 HI Lite CRT which was perfect!
The CRT was used in a much more deserving set, a Zenith 23NC**. The last roundie Zenith made.
The set isn't an RCA clone, a lot different.
Old 09-16-2020, 11:16 AM
Personally if I had more space I'd be interested in picking that set up... from what I understand they were sort of like a portacolor with a transformer power supply and traditional roundy sweep circuits.
The worst limiting factor of picture quality in the portacolor was the coarse dot pitch CRT...the roundys didn't have that limitation... There's a LOT LESS GE roundys surviving than RCA or Zenith so IMO they are worth preserving more than the RCA designed off brand clones.
The premium sets are nice to collect, but you can't fully appreciate a Dumont till you've experienced a Muntz.
Old 09-16-2020, 11:38 AM
Well, it's about 50 miles away from me, much closer than the stromberg carlson x-21 was, so I guess it's worth a try!
Old 09-16-2020, 07:44 PM
Tom9589 Tom9589 is offline
The GE Portacolors had two different CRTs: 11SP22 and the 11WP22. The early 11SP22 had the coarse dot pitch and the later 11WP22 had a much finer dot pitch - a much better picture. I owned one of each.
Old 09-17-2020, 11:18 AM
Actually, the GE KC and KD chassis is a glorified Portacolor!
The AC chassis set is a bit different using 6AU8's in the color circuit.
It's worth looking the schematic! IIRC, they made a rectangular set with a similar chassis.
Old 09-17-2020, 01:27 PM
Electronic M, your comment about not fully appreciating a DuMont until you have experienced a Muntz reminds me of my first high school job in a garage. A 1959 Rambler came in and I got the job to fix it. I groused a little bit about doing it and one of the other mechanics said I couldn't appreciate working on a Lincoln until I worked on a few Ramblers! He was right.
Old 09-17-2020, 02:04 PM
DavGoodlin's Avatar
Motorola Minion
The CA chassis had a CTC15 clone look to it in many ways but GE revised some most circuits to use their tubes. i.e. 6BH11, 6FM7 etc.
I saw one of the CA or CB sets on an episode of "Mister Ed" when Wilbur brought home
a color TV one day, in an Italian Provincial IIRC.
-Dave G
Old 09-19-2020, 08:29 AM
Tim Tress Tim Tress is offline
I trained on a CX chassis, almost 50 years ago. It was RCA made, and seemed to be close to the CTC-12, with a few elements of the CTC-15. I think that was the last RCA chassis that they used.
Old 09-19-2020, 12:09 PM
well, I'm close to having it in my paws!
Old 09-19-2020, 10:23 PM
It's mine!
https://imgur.com/6uhmLi7
very bad cataract
https://i.imgur.com/VuWhH0y.jpg
https://imgur.com/vSwF40g
https://imgur.com/Yty9iP5
reg cap is loose fitting, falls off easily.
https://imgur.com/N9dESJM
https://imgur.com/b1TBULo
https://imgur.com/rQgBKXh
now that is VERY stupid...
rather than replacing a bad socket, someone soldered the wire to the focus pin of the CRT? WTF?
https://imgur.com/58xIKOB
blue is a bit low, but the CRT is not dead, not as strong as the one in my CTC-16xl, but could be worse.
gonna let it sit a bit and wake up
