Old 09-09-2022, 09:54 AM
Ok that’s the network that has several legs on it I believe.
Old 09-09-2022, 09:59 AM
If that’s bad I Doubt I could locate that part it looks like it could be made up it’s all resistors.
Old 09-09-2022, 10:03 AM
If bad, it would have to be made up on a small pcb, It's been done before.
https://retrovoltage.com/2014/10/09/...tric-circuits/
Old 09-09-2022, 10:19 AM
So this agc network would this be a cause for the voltage being pulled down via the 6hs8 tube ?
Old 09-09-2022, 10:27 AM
No, if not working the way it should, the AGC voltage/pulses would be all wrong, and tuning and IF would be all messed up and you would not be able to tune in anything.
Old 09-09-2022, 10:30 AM
Ok but when I get the tube I’ll try it but overall I still have the voltage dropping so if the tube don’t work out I’m still looking for a cause for the voltage dropping.
Old 09-09-2022, 03:27 PM
Timmy
Could you sum up what is wrong with the TV NOW without going
through the previous repairs.
In other words plug it in & see what happens like you never seen the set before.
I have lost track......
Prev screen shot looked good. But long distance troubleshooting is a challenge !
Many of us could take the TV like shown in the screen shot & vastly improve it
in seconds. That would maybe weed out problems.
Also remember NEVER trust a tube checker. The best checker is a known
good NOS brand name tube. We had an advantage here. I could turn
around & pull a tube from the shelf. It was abt 8' long & 5' high with sleeves of common tubes, more old numbers on shelves in the crapper.
Old 09-09-2022, 03:40 PM
Timmy
ok first the pic with the face was to rule out the video amp and output by injecting video. Turn it on b+ good few seconds later b+ drops and in doing so the horizontal oscillator won’t run because b+ is being pulled down to far so in using the sets IF cannot get an image weather or not the voltage being draw down has to do with that I don’t know maybe there is an IF problem as well. I have a tube coming maybe this is the problem I don’t know until I get it to try.
Old 09-10-2022, 08:58 AM
Got the 6hs8 no different but I did pull the 6cg7 AGC and vertical multi voltage stayed up I got a new 6cg7 made no difference so the one vertical half is working because I have a full screen so that may leave it to an AGC problem still bearly any sound scratchy static sound and with the 6cg7 in I can here a buzzing from somewhere. If k3 is bad or the cap inside is shorted I can make it up but it shows a line under the 94k resistor which is the .002 cap but it also shows a ground in the center of the line so where does the ground come from. I don’t remember seeing a cap with 3 legs. Does this mean 2 caps one on each side of the 94k resistor both to ground.
Old 09-10-2022, 05:59 PM
Does anyone know what this T line means 2 .002 caps one on each end of the 94k resistor
Old 09-10-2022, 07:21 PM
That is another couplet, like K1. K3 is a combo part, 2 resistors 1 cap in 1 package.
Old 09-10-2022, 07:24 PM
But the T does it represent 2 caps one on each side of the 94k
Old 09-10-2022, 07:52 PM
Tim's Avatar
Tim Tim is offline
It intends to show .002 distributed across the resistor. When making a replacement put a .001 to ground on each end of the resistor so the total is .002
Is there another resistor that is covered by the black splotch?
Tim
Old 09-10-2022, 09:59 PM
remove V1,V2,V3 ,V7,V8.
feed video back to test point B like you did before and see how long it can run like that.
Old 09-11-2022, 06:10 AM
No there is not only one for this area.
