Old 04-21-2023, 09:45 AM
pac.attack76's Avatar
Stuck in the past
coby tftv3227 turns on then off
Turns on and display comes up. During this time, you can here what sounds like a voltage leak. A hiss. Then shuts off. What should I check on the power board?
Genesis does what Nintendon't
Old 04-21-2023, 10:21 AM
damen's Avatar
damen damen is offline
That set uses a backlight inverter board for the fluorescent bulbs. Check around the transformers on that board, check the backside for evidence of over heating. Also, look at the board in a darkened room for arcing while its on.
Old 04-21-2023, 05:30 PM
Stuck in the past
Ok, will do. I'll update soon.
Old 04-28-2023, 09:59 AM
JohnCT's Avatar
JohnCT JohnCT is offline
Check carefully the short pink and white wires (typical colors used) from the inverter board into the display. These are thin high voltage wires and sometimes they lay cross each other and will eventually arc a pin hole where they touch.
With the TV off, make sure none of the wires cross each other. If so, separate them and tack down with RTV. If there's a pin hole, a tiny dot of RTV will stop the leak although they usually don't arc if they're just separated.
If that's not it, there's a good chance your problem is inside the display - either a cracked or burned out CCFL tube. When they crack or burn out, the voltage across the dead tube will cause arcing, usually to ground. Once in a while, the end socket at the ends of each CCFL tube will corrode and cause bad connections.
There's also a chance of a burned out inverter transformer. Carefully look at each transformer on the inverter board and see if one looks more cooked than the rest. If so, the trans could just be bad or the CCFL tube it drives could be burned open which causes an overvoltage at the transformer.
John
Old 04-28-2023, 10:07 AM
Stuck in the past
Ok I'll let you know what I find.
Old 05-23-2023, 08:10 AM
liammc00's Avatar
liammc00 liammc00 is offline
real TVs have a CRT
I have worked on an older Coby tv that used fluorescent backlights. The one I had needed all the caps in PSU changed. So if you get the set up and running I would check the caps in PSU especially if there Capxon branded as those have very high failure rate in Coby TVs.
Old 05-23-2023, 08:46 AM
Stuck in the past
Yeah this one had the fluorescent backlights and capxon caps. I decided to tear it down and dispose of it.
